CF does't responds to changed parameters
zhanghaijason
Post by zhanghaijason »
I followed a tutorial shows how to control the 5th motor on CF. That tutorial adds two parameters in CF client to change the values. The parameter value should control PB5 and PB8's output (0 or 1). I successfully upload the firmware. However, when I cahnged the parameter, the output of PB8 and PB5 are always 0. I checked my code is the same with the tutorial. The tutorial was written about 1 year ago. And I updated the firmware to the lastest and modified it based on the tutorial. Is it possible that the new firmware conflicts with the tutorial? The tutorial uses pinsource2, timer5, GPIOA, PH8, PH5, pwm1 on PA2. The tutorial is attached.
Thanks!
pwmTutorial2.pdf
(992.49 KiB) Downloaded 367 times
Re: CF does't responds to changed parameters
It is possible that something has broken during development. It is a lot to setup. Can you share your code, either on github or here?
zhanghaijason
tobias wrote: Fri Sep 21, 2018 8:17 am It is possible that something has broken during development. It is a lot to setup. Can you share your code, either on github or here?
Hi Tobias,
The code are attached.
motorsDriver.c
 * motorsDriver.c
 *  Created on: Sep 20, 2018
 *      Author: bitcraze
#include <stdbool.h>
#include "stm32fxxx.h"
#include "motorsDriver.h"
// FreeRTOS includes
#include "FreeRTOS.h"
#include "task.h"
#define BASE_FREQ (328125)
static bool isInit=false;
// initialize output
void GPIOInit(){
	GPIO_InitTypeDef GPIO_Struct;
	// clocl setup
	RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
	// TIMER SETUP
	GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_TIM5);
	GPIO_Struct.GPIO_Mode=GPIO_Mode_AF;
	GPIO_Struct.GPIO_OType=GPIO_OType_PP;
	GPIO_Struct.GPIO_Pin=GPIO_Pin_2;
	GPIO_Struct.GPIO_PuPd=GPIO_PuPd_DOWN;
	GPIO_Struct.GPIO_Speed=GPIO_Speed_2MHz;
	// initialize GPIOA with setup config
	GPIO_Init(GPIOA, &GPIO_Struct);
void timerInit(){
	// Struct to initialize/configure TIM5
	TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
	//clock
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
	// Configure TIM_TimeBaseStruct
	TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;
	TIM_TimeBaseStruct.TIM_Prescaler=0;
	TIM_TimeBaseStruct.TIM_ClockDivision=0;
	TIM_TimeBaseStruct.TIM_Period=255;
	TIM_TimeBaseStruct.TIM_RepetitionCounter=0;
	//initialize timer
	TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStruct);
	//enable timer5
	TIM_CtrlPWMOutputs(TIM5, ENABLE);
	//set compare register values
	TIM_SetCompare3(TIM5,0x00);
	// start timer
	TIM_Cmd(TIM5, ENABLE);
void pwmInit(){
	TIM_OCInitTypeDef TIM_OCStruct;
	// configure TIM_OCStruct
	TIM_OCStruct.TIM_OCMode=TIM_OCMode_PWM1;
	TIM_OCStruct.TIM_OutputState=TIM_OutputState_Enable;
	TIM_OCStruct.TIM_OCPolarity=TIM_OCPolarity_High;
	TIM_OCStruct.TIM_Pulse=255;
	//initialize on channel 3
	TIM_OC3Init(TIM5, &TIM_OCStruct);
	//enable preload
	TIM_OC3PreloadConfig(TIM5, TIM_OCPreload_Enable);
void motorDriverInit(){
	if(isInit)
		return;
	GPIOInit();
	timerInit();
	pwmInit();
	isInit=true;
void motorSetRatio(uint8_t ratio){
	TIM_SetCompare3(TIM5,ratio);
void motorSetFreq(uint16_t freq){
	TIM_PrescalerConfig(TIM5, BASE_FREQ/freq, TIM_PSCReloadMode_Update);
motorsDriver.h
 * motorsDriver.h
 *      Author: bitcraze
#ifndef SRC_DRIVERS_INTERFACE_MOTORSDRIVE_H_
#define SRC_DRIVERS_INTERFACE_MOTORSDRIVE_H_
#include <stdint.h>
#include "config.h"
void GPIOInit();
void timerInit();
void pwmInit();
// motor initilization
void motorDriverInit();
void motorSetRatio(uint8_t ratio);
void motorSetFreq(uint16_t freq);
#endif /*SRC DRIVERS INTERFACE MOTORSDRIVER_H_*/
pwmMotors.c
 * pwmMotors.c
 *  Created on: Sep 21, 2018
 *      Author: bitcraze
#include <stdint.h>
#include <string.h>
#include <unistd.h>
#include "config.h"
#include "deck.h"
#include "param.h"
#include "task.h"
#include "system.h"
static bool isInit;
static int prevDir=-1;
static uint8_t prevSpeed=255;
static uint8_t speed;
static uint16_t PERIOD_SLEEP_TIME_IN_MS=100;
typedef enum{
     stop=0,
	 cw=1,
	 ccw=2
} Mode;
static Mode mode;
void pwmMotors(void* arg);
void pwmWrite(uint8_t ratio){
   motorSetRatio(ratio);
void stopMotor(){
   motorSetRatio(0);
static void pwmMotorsInit(DeckInfo* info){
   if (isInit)
       return;
	motorDriverInit();
	pinMode(DECK_GPIO_IO1, OUTPUT);
	pinMode(DECK_GPIO_IO2, OUTPUT);
	mode=1;
	speed=255;
	motorSetFreq(10000);
	xTaskCreate(pwmMotors, "pmwMotors", configMINIMAL_STACK_SIZE,NULL, /*PRIORITY*/ 1, NULL);
	isInit=true;
void pwmMotors(void* arg){
    systemWaitStart();
	TickType_t xLastWakeTime;
	while(1){
	  xLastWakeTime=xTaskGetTickCount();
	if(prevDir == mode&& prevSpeed == speed){
	  vTaskDelayUntil(&xLastWakeTime, M2T(PERIOD_SLEEP_TIME_IN_MS));
	  continue;
	switch(mode){
	    case stop:
		     digitalWrite(DECK_GPIO_IO1,0);
			 digitalWrite(DECK_GPIO_IO2,0);
			 stopMotor();
			 break;
		case cw:
		     stopMotor();
		     digitalWrite(DECK_GPIO_IO1,1);
			 pwmWrite(speed);
			 break;
		case ccw:
		     stopMotor();
			 digitalWrite(DECK_GPIO_IO2,1);
			 pwmWrite(speed);
			 break;
        default:
             break;
	 prevDir=mode;
	 prevSpeed=speed;
	PARAM_GROUP_START(xMotorPWM)
	PARAM_ADD(PARAM_UINT8, mode, &mode)
	PARAM_ADD(PARAM_UINT8, speed, &speed)
	PARAM_GROUP_STOP(xMotorPWM)
	static const DeckDriver pwmMotors_deck={
	   .vid=0,
	   .pid=0,
	   .name="pwmMotors",
	   .usedPeriph=DECK_USING_TIMER5,
	   .usedGpio=DECK_USING_PB5 | DECK_USING_PB8 | DECK_USING_RX2,
	   .init=pwmMotorsInit
	DECK_DRIVER(pwmMotors_deck);
I think those are the three important files. Thanks
zhanghaijason
Hi Tobias,
Thanks for your help. I found the reason. I put the config.mk in the wrong folder. I am stupid.... Thanks!
