So my radio is able to find the quadcopter through the client and when running code, but is unable to find it when I hit 'initiate cold boot' through Connect->Bootload.
Of note is that I changed the address of my quadcopter from 0xE7E7E7E7E7 to 0xE7E7E7E7E8 to avoid interference from others in the same building, but I made sure to modify the correct lines in cflib, those being:
self.set_address((0xE7,)*4 + (0xE8,)) //drivers/crazyradio.py:141
DEFAULT_ADDR_A = [0xe7, 0xe7, 0xe7, 0xe7, 0xe8] //crtp/radiodriver.py:61
DEFAULT_ADDR = 0xE7E7E7E7E8 //crtp/radiodriver.py:62Thanks,
Dio-
