altitude hold/hover
altitude hold/hover
Hello all,
Has someone written a code for altitude hold/hover? that I can use it on my crazyflie1.0.
Thanks in advance
Thanks in advance
Re: altitude hold/hover
I think altitude hold should work out of the box on 10dof variant (pressure sensor might need foam isolation). Hover does not work though.
Thanks for your reply!
Currently I'm working on a new proyect, but every time I try to flash the firmware I get the following error,
14:15:07 **** Build of configuration Default for project crazyflie-firmware ****
make cload
../crazyflie-clients-python/bin/cfloader flash cflie.bin stm32-fw
Restart the CrazyFlie you want to bootload in the next 10 seconds ...
Cannot connect the bootloader!
make: *** [cload] Error 255
14:15:25 Build Finished (took 18s.387ms)
I don't know what it means, and I don't know what to do. I'm using the Crazyflie 1.0 and Bitcraze VM 0.5
Thanks in advance
make cload
Thanks in advance
For the bootloader to connect you need to reboot your Crazyflie 1 just after clicking on the cold boot button, are you doing that?
Which firmware's version (crazyflie 1.0) have altitude hold mode working properly?
Altitude hold should work with the latest version of the firmware for Crazyflie 1.0 which was 2017.06.
Thanks. I'll check it out.
I tested the altitude hold mode (firmware 2017.06) with my crazyflie 1.0 but it didn't work 100%. I am able to choose a setpoint using the throttle but the drone sometimes falls or ascends losing the target altitude. I am using the foam to protect the sensor but this problem is still happening. What else can I do to achieve a good altitude control using crazyflie 1.0?
Thanks in advance.
Thanks in advance.
First thing to check: do you have a Crazyflie 1.0 10DOF, if not there is no pressure sensor and altitude hold will use only the accelerometer which means that it is going to drift after a while.
If you have the pressure sensor, altitude hold is dependent of the ambiant pressure change. You can test if the ambiant pressure is changing a log in your environment by loggin the pressure reading using the Crazyflie client, for example big pressure change can normally be seen by opening and closing the room door/windows. If the ambiant pressure fluctuate a log there is not much that can be done to get a more stable hold.
If the pressure is more stable than what you are observing, there might be hope to improve things with better firmware implementation. This is something that requires looking into and tweaking the Crazyflie source code.
Re: altitude hold/hovera
Thanks for the reply, arnaud.
My crazyflie 1.0 is 10 DOF and the room where I tested was closed. Could you give me a tip, which files(codes) do I have to change in order to improve the altitude hold mode? I use the crazyflie VM too and I can change the codes.
Thanks in advance.
Thanks in advance.
