test loco position but cfclient no any response
- Expert
Re: test loco position but cfclient no any response
I will try it
- Expert
and I have adjusted the self.is_loco_deck_active = True, how to generate a windows version cfclient?
- Expert
hi, arnaud:
after command line, don't improve the cfclient's speed.
sudo apt-get remove python3-pyqtgraph
pip3 uninstall pyqtgraph
pip3 install pyqtgraph
- Expert
and I also try the windows version, update the latest crazyflie-clients-python, the speed is normal. so maybe the VM issue ?
After the commands you still get the same errors in the console or is it just the speed that is slow without console print?
- Expert
still get the same errors in the console.
