Hi everyone,
I want to extract raw IMU data from CF2.0. For the last few days I've been using rostopic echo /crazyflie/imu to read the data. My question is: when I read data using this method do I get raw data from the IMU or the data I get has been filtered in some way? If the data has been filtered, how do I get unfiltered data?
Thanks in advance.
Crazyflie 2.0 IMU data
Re: Crazyflie 2.0 IMU data
This is unfiltered, but converted to the standard ROS units. However, the sampling frequency over the radio is very limited (100 Hz max), while the IMU generates data up to 4 kHz. If you really want the raw data at full frequency, you'll need a wired connection (I used a SEGGER J-LINK debugger before to stream data at full speed). Other people also experimented with logging to a uSD card.
Thank you for quick answer, cheers!whoenig wrote: ↑Wed May 02, 2018 4:39 pm This is unfiltered, but converted to the standard ROS units. However, the sampling frequency over the radio is very limited (100 Hz max), while the IMU generates data up to 4 kHz. If you really want the raw data at full frequency, you'll need a wired connection (I used a SEGGER J-LINK debugger before to stream data at full speed). Other people also experimented with logging to a uSD card.
Hi, whoenig. I saw that you said the imu in ROS is already converted to ROS units. Can I ask what's the different between ROS units and the raw imu data unit?
It depends on what variables you log. In this case it's just non-SI units to SI units, see https://github.com/whoenig/crazyflie_ro ... #L596-L604.
