Can not set anchor positions
Huibean
Post by Huibean »
After setting 6 anchor, I was trying set the anchor positions
But each time I change location value and click write to anchors button, nothing changed, and when I click Get from anchors button, value reset to all (0, 0, 0)
Then I trying to set position through python lib and the LoPoAnchor's set_position func stuck
import cflib.crtp
from cflib.crazyflie.log import LogConfig
from cflib.crazyflie.mem import MemoryElement
from lpslib.lopoanchor import LoPoAnchor
cf = Crazyflie(ro_cache=None)
while True:
    devices = cflib.crtp.scan_interfaces()
    if len(devices) > 0:
        break
    else:
        print("no device")
device_interface = devices[0][0]
cf.open_link(device_interface)
lopo = LoPoAnchor(cf)
lopo.set_position(1, (1, 0, 0))
Re: Can not set anchor positions
Are you using the latest version (from master branch) of both the Crazyflie firmware and the lps-node firmware? This functionality is still in development (it is being finished this week) and it works with the very latest firmwares.
Huibean
Post by Huibean »
Thanks Arnuad! It works now, after reflashing Crazyflie firmware
