[Crazyradio PA] how to set BANDWIDTH
netkimjh
Post by netkimjh » Thu Mar 30, 2017 4:58 pm
Re: [Crazyradio PA] how to set BANDWIDTH
Post by arnaud » Fri Mar 31, 2017 1:37 pm
This will not be a problem on the Crazyradio side but on the PX4 side. The client is actively scanning all channels at datarate 250K, 1M and 2M. If PX4 configures the Crazyflie 2 radio using one of these datarate this is the one the client will detect.
In other work the crazyradio and Crazyflie client are working out of the box in all datarate supported by Crazyradio, the one used depends of the Crazyflie setting.
netkimjh
Post by netkimjh » Tue Apr 04, 2017 5:22 pm
Post by arnaud » Tue Apr 04, 2017 5:34 pm
What i mean is that this is a Crazyflie configuration not a crazyradio configuration.
If you are using the stock crazyflie fimware you can configure the datarate using the crazyflie client: https://wiki.bitcraze.io/doc:crazyflie: ... figuration
netkimjh
Post by netkimjh » Thu Apr 06, 2017 7:50 pm
Post by arnaud » Wed Nov 07, 2018 5:32 pm
These tools have been developed for the Crazyflie firmware (the stock firmware delivered with the Crazyflie and developed by Bitcraze). I have never used the PX4 firmware so I am not able to help with configuring it. Hopefully someone will pass by with knowledge about the PX4 firmware otherwise I suggest you ask the maintainer of the Crazyflie PX4 port.
Last bumped by netkimjh on Wed Nov 07, 2018 5:32 pm.
