As already started in comment to "Loco positioning system" Blog post, I'm doing (or want to do) position control with an "arbitrary" source of position estimation.
In my case I'm using a prototype of an optical flow odometer (4 stereo sensors), which is mounted on the crazyflie using the deck-interface. You can think of it as a 3D optical "mouse".
I have already written a custom deck driver to obtain sensor data via I2C, and to perform normalization (mapping of axes, scaling sensitivity).
Arnaud, thank you for the hint. I had a good look at the source, and I'm now using stateEstimatorEnqueuePosition() which is part of estimator_kalman.c to perform position updates from my deck-driver to kalman-filter.
I already had a look using log-system/plotter so I could see the behavior of the kalman-filter to my "injected" position updates. It is looking good so far - very clean/smooth. Next step will be getting ROS up and running, and then try to set a "known point" to the position controller and see what happens
~Florian
EDIT:
Arnaud, is there a function I can call to update the position-set-point of the position-controller (on crazyflie), and is there a function to set speed, so to say speed-set point if I want to alter the position-set-point by means of moving away from the current one?
I had a look in commander.c and position_controller_pid.c but couldn't find anything appropriate, am I mssing something?
