Hi guys,
I would like to launch multiple crazyflies using ROS. What would be the best way to approach this? As of now, for me to launch multiple crazyflies I need to create multiple nodes for each crazy flie on my launch file, I would like to do it more efficiently. My set up uses Vicon.
Thanks!
						Swarm of Crazyflies
Re: Swarm of Crazyflies
You can find an example here: https://github.com/whoenig/crazyflie_ro ... con.launch
While that uses multiple nodes, those are short-living (and therefore do not take much resources except at startup). The actual work is done in a single node called the crazyflie_server. This has been tested for up to 6 CFs.
Best,
Wolfgang
Best,
Wolfgang
