A question about macro "RATE_DO_EXECUTE"
Firmware/software/electronics
linlin2017
Post by linlin2017 » Sat Nov 04, 2017 8:35 am
Hi developers,
I am reading source code of crazeflie 2.0, and I don't understand some code. For example, why we judge the macro "RATE_DO_EXECUTE()" in function stateController() ?
Thanks! :)
Re: A question about macro "RATE_DO_EXECUTE"
Post by tobias » Mon Nov 06, 2017 1:26 pm
The stabilizer task runs at 1kHz but only the rate stabilization needs to run that fast. The attitude stabilization can run slower and the velocity stabilization even slower then that. So the RATE_DO_EXECUTE is just a divider of the update rate.
linlin2017
Post by linlin2017 » Tue Nov 07, 2017 1:20 pm
In your answer, does ' the rate stabilization' mean body angular velocity stabilization? Thank you.
Post by arnaud » Tue Jan 16, 2018 1:54 pm
Yes, the rate stabilization is the body angle velocity stabilization.
