Purpose of CrazyRadioPA's 74HC1GT50
Firmware/software/electronics
jynik
Post by jynik » Tue Jun 28, 2016 2:26 am
I've been working with some nRF24LU1+ firmware on the CrazyRadio PA and would like to add SPI Master mode support.
There's no issue with the MOSI, MISO, SCK pins. However, I'm a bit concerned about contention on the CSN (P0.3) pin.
Table 98 in the nRF24LU1+ product spec notes that for P0ALT[1:0] = "01", P0.3 is "Configured as output, typically used for Master SPI, see chapter 9 on page 99." That's not at all comforting -- I would hope the pin direction is still controlled by P0DIR!
If setting up master mode via P0ALT[1:0] = "01" sets up P0.3 as an output, then I'd have contention between the nRF24 and the 74HC1GT50 output.
Thus, I'm considering removing the non-inverting buffer and directly connecting the CSN pin on P2 to the nRF24LU1+. I'd like to know:
  • Why was a non-inverting buffer used on the CSN pin, but not on other SPI pins?
  • Why does the output of this buffer go to both P0.3 and P0.5?
  • Any warnings/concerns you'd advise WRT to removing it (in terms of using/re-flashing the CrazyRadio PA)?
  • Has anyone looked SPI Master mode and the effect on the P0.3 directionality (if there actually is any)?
Thanks,
Jon
Re: Purpose of CrazyRadioPA's 74HC1GT50
Post by arnaud » Tue Jun 28, 2016 9:41 am
- The non-inverting bugger is aimed at being used for PPM input. The use case was to connect Crazyradio directly to a RC transmitter PPM output. These output can have a level of up to 12V to the buffer is doing voltage conversion.
- For PPM input it is connected both to the interrupt input and to the timer input
- If you plan to work with the Crazyradio firmware make sure you are still able to flash it via SPI (should not be a problem if you want to keep CSN on the connector).
- I have never looked at SPI master and not heard of anyone else with Crazyradio using SPI master.
I am curious to know what is your use-case for SPI master on Crazyradio
/Arnaud
jynik
Post by jynik » Thu Jun 30, 2016 4:12 am
Hi Arnaud,
Thanks for the quick reply and for detailing the design elements that I wasn't familiar with; this makes a lot more sense now!
Beyond its use with the CrazyFlie, I've found the CrazyRadio PA to be a really nice and accessible piece of hardware to experiment with nRF24LU1+ for various projects.
In this case, the SPI master functionality is not intended for use with the CrazyFlie, but as a means for me to reflash other CrazyRadio PAs in the wake of "oopsies" and other SPI flash devices in general.
So... tl;dr -- I'm venturing off into some custom firmware and use-cases.
Cheers,
Jon
Post by arnaud » Thu Jun 30, 2016 7:56 am
I guessed that you wanted to use Crazyradio with something else than Crazyflie (It is intended: the reason it is called Crazyradio and not "Crazyflie radio dongle" is because we see use for more than the Crazyflie ;). I had the same idea as your of using a crazyradio to flash a crazyradio but the chip select situation is a bit problematic.
If you are interested I have recently made some experiment on easy to make Crazyradio programmer. The first one is a "fix" script for Raspberry-pi that will make the Crazyradio start in bootloader mode. The second is an arduino program to make a programmer out of a 3.3v Arduino (the 3.3v voltage is important there). the mechanic works really great with the Adafruit feather M0: https://goo.gl/9Fv8pN. If you are interested on testing this kind of arduino programmer I can rush and publish some code for it.
/Arnaud
whoenig
Post by whoenig » Mon Jul 25, 2016 8:47 pm
Hi Arnaud,
I would be interested in any solution for (re)flashing the Crazyradio. I think I "broke" a few by flashing a faulty firmware (i.e. I can't get into bootloader mode anymore).
Thank you!
Wolfgang
Post by arnaud » Tue Jul 26, 2016 6:08 am
Hi Wolfgang,
A little while ago I pushed a "de-bricking" script that uses a Rasperry pie on the Crazyradio repos: https://github.com/bitcraze/crazyradio- ... bootloader.
Otherwise I will try to clean-up my code and push an Arduino flasher during the week.
/Arnaud
