Crazyradio Loss Rate [solved]
I'm using the Cflie library from Jan Winkler. When I tested the connection I found out, that there is approximately a 20% loss rate. Is this normal? Meaning that it is also so high for the normal Crazyflie communication?
Re: Crazyradio Loss Rate
Could it be, that it is also depending on the package length?
When i tested with 1byte data it was 20%
when i tested with 19byte data it was 80%
The loss rate is almost 0% with 250K. So the error was using the 2M
