Crazyradio Loss Rate [solved]
Firmware/software/electronics
Slaxx
Post by Slaxx » Tue Sep 29, 2015 11:58 am
I'm using the Cflie library from Jan Winkler. When I tested the connection I found out, that there is approximately a 20% loss rate. Is this normal? Meaning that it is also so high for the normal Crazyflie communication?
Slaxx
Re: Crazyradio Loss Rate
Post by Slaxx » Tue Sep 29, 2015 3:04 pm
Could it be, that it is also depending on the package length?
When i tested with 1byte data it was 20%
when i tested with 19byte data it was 80%
Slaxx
Post by Slaxx » Wed Sep 30, 2015 9:00 am
The loss rate is almost 0% with 250K. So the error was using the 2M
