cannot get scan working in C
Firmware/software/electronics
gherlein
Post by gherlein » Sat Jul 04, 2015 6:37 pm
I have C code to open the USB and set up the CrazyRadio. I think that's working OK. I don't really have a way to test that!
So, I was writing a function to scan the radio channels and see if I can find the CF2. I've tried a pile of stuff and finally have to ask for help. Should this function work if all the rest of my code is working to set up the radio?
int
scanChannels(void)
unsigned char b[1];
unsigned char a[3];
unsigned char c[64];
int r=0;
a[0]=0xF0;
a[1]=0x01;
a[2]=0x01;
r = libusb_control_transfer(dev_handle, 0x40, 0x21, 0, 125, (unsigned char*)&a, 3, 1000);
if(r<0)
printf("error writing scan command\n");
return 0;
printf("wrote %d bytes to command a scan...\n",r);
sleep(2); // in case the scan takes some time
memset(c,0xff,64);
r = libusb_control_transfer(dev_handle, 0xC0, 0x21, 0, 0, (unsigned char*)c, 63, 1000);
if(r==0)
printf("got no reply from channel scan\n");
return 0;
if(r<0)
printf("error reading scan results\n");
return 0;
printf("read %d bytes of scanned channel data...\n",r);
for(r=0;r<64;r++)
printf("Channel %d: %d\n",r,c[r]);
return 0;
