I want to doe some development using the VM. I went to install VMPlayer but I keep getting an error while installing
It says;
Line 1089
Char 7
Code 0
Expected ")"
Then it gives a URL and button choise to continue or end. Which ever button I click simply returns a blank Greyscale window of the installer but it stops installing.
I then need to go to the task manager to close this window.
I am running windows 8.1. Is this my problem?
[SOLVED] VMplayer trouble installing
Reason: Issue has been solved
Re: VMplayer trouble installing
OK so I solved this.
Glad to read that you solve your problem. Could you share what the problem was?
The solution to this problem is exactly as explained by "abhommies" at this link
https://communities.vmware.com/message/2326717
