[SOLVED]Would nRF24LU+ be recognized with the chip type ...
baicker
Post by baicker » Thu Jan 02, 2014 11:28 am
when i soldered the crazyradio completly without flash the fireware into the nRF24LU+, i plug it to the pc, would it be recognized with the chip type?
Re: Would nRF24LU+ be recognized with the chip type by defa
Post by tobias » Fri Jan 03, 2014 8:28 am
Yes it should as there is a bootloader flashed from the factory which you can use to program your own firmware with.
baicker
Post by baicker » Sun Jan 05, 2014 3:26 am
tobias wrote:Yes it should as there is a bootloader flashed from the factory which you can use to program your own firmware with.
thanks tobias. so i can confirm there is something wrong with my hardware or connection.
