usb.core.USBError: [Errno 32] Pipe error
Posted: Sat Oct 19, 2019 3:37 pm
I've recently got hold of 2 Crazyradio PA's to see if they would be suitable for a personal project. I've then tried to run ptx.py and prx.py from the examples folder in https://github.com/bitcraze/crazyradio-firmware
I've tried both devices, in 3 different PCs running a combination of Fedora 26 and Ubuntu 18.04
In all cases I get the following:
When I plug the radios in D3 and D4 both light up simultaneously, and then turn off again and stay off, which I believe is correct behaviour. When I plug one of the radios in dmesg shows:
lsusb gives:
I've tried upgrading the firmware on one of the radios with the 0.53 release, and again with a binary I built fresh from the repo. I have also tried multiple different USB ports (both USB3 and USB2), as I found comments suggesting that USB3 ports might have issues. I always get the same error.
Any ideas what might be the problem?
File "ptx.py", line 8, in <module>
radio.set_mode(Crazyradio.MODE_PTX)
File "../lib/crazyradio.py", line 221, in set_mode
_send_vendor_setup(self.handle, SET_MODE, mode, 0, ())
File "../lib/crazyradio.py", line 309, in _send_vendor_setup
wIndex=index, timeout=1000, data_or_wLength=data)
File "/usr/lib/python2.7/site-packages/usb/core.py", line 1043, in ctrl_transfer
self.__get_timeout(timeout))
File "/usr/lib/python2.7/site-packages/usb/backend/libusb1.py", line 883, in ctrl_transfer
timeout))
File "/usr/lib/python2.7/site-packages/usb/backend/libusb1.py", line 595, in _check
raise USBError(_strerror(ret), ret, _libusb_errno[ret])
[ 6606.745101] usb 3-2: new full-speed USB device number 5 using xhci_hcd
[ 6606.873723] usb 3-2: New USB device found, idVendor=1915, idProduct=7777
[ 6606.873728] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[ 6606.873731] usb 3-2: Product: Crazyradio PA USB Dongle
[ 6606.873733] usb 3-2: Manufacturer: Bitcraze
[ 6606.873736] usb 3-2: SerialNumber: 16B11C3CB9
[root@localhost]$ lsusb -d 1915:7777 -v
Bus 003 Device 005: ID 1915:7777 Nordic Semiconductor ASA
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1915 Nordic Semiconductor ASA
idProduct 0x7777
bcdDevice 0.53
iManufacturer 1 Bitcraze
iProduct 2 Crazyradio PA USB Dongle
iSerial 29 16B11C3CB9
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 6
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 6
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
