[Ubuntu 16.04 LTS 64-bit] Crazyradio possibly broken, USB Error 32 (pipe Error) in cfclient
Lama
Post by Lama » Sun Feb 25, 2018 4:06 pm
Hello again,
I have now another problem with my Crazyradio PA.
After a few successful flights today with my crazyflies,the Crazyradio suddenly stopped working:
When i start the cfclient, it just say "Scanning", without any success. In the terminal, the following message is shown:
===== 2018.02.25 16:02:59 =====
  File "/root/bitcraze/crazyflie-clients-python/src/cfclient/ui/main.py", line 836, in scan
    self.interfaceFoundSignal.emit(cflib.crtp.scan_interfaces(address))
  File "/root/bitcraze/crazyflie-lib-python/cflib/crtp/__init__.py", line 65, in scan_interfaces
    found = instance.scan_interface(address)
  File "/root/bitcraze/crazyflie-lib-python/cflib/crtp/radiodriver.py", line 349, in scan_interface
    for c in self._scan_radio_channels(cradio)]
  File "/root/bitcraze/crazyflie-lib-python/cflib/crtp/radiodriver.py", line 280, in _scan_radio_channels
    return list(cradio.scan_channels(start, stop, (0xff,)))
  File "/root/bitcraze/crazyflie-lib-python/cflib/drivers/crazyradio.py", line 262, in scan_channels
    self.set_channel(i)
  File "/root/bitcraze/crazyflie-lib-python/cflib/drivers/crazyradio.py", line 174, in set_channel
    _send_vendor_setup(self.handle, SET_RADIO_CHANNEL, channel, 0, ())
  File "/root/bitcraze/crazyflie-lib-python/cflib/drivers/crazyradio.py", line 302, in _send_vendor_setup
    wIndex=index, timeout=1000, data_or_wLength=data)
  File "/usr/local/lib/python3.5/dist-packages/usb/core.py", line 971, in ctrl_transfer
    self.__get_timeout(timeout))
  File "/usr/local/lib/python3.5/dist-packages/usb/backend/libusb1.py", line 819, in ctrl_transfer
    timeout))
  File "/usr/local/lib/python3.5/dist-packages/usb/backend/libusb1.py", line 552, in _check
    raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 32] Pipe error
I already installed a new firmware (0.53), but without any success again.
After plug in the crazyradio, the two LEDs are blinking for one moment.
Im getting the error on two different PCs (1VM and 1 Ubuntu 16.04), so im guessing their is a Hardware Problem ? :?
Thanks for your help.
Greetings from Burbach
Lama
Re: Crazyradio broken ?
Post by arnaud » Sun Feb 25, 2018 7:04 pm
a hardware problem is not the first things I would suspect since we have never seen a Crazyradio dying suddenly like that (not that it could never happen but I expect it to be very rare).
If both LEDs are blinking when you insert it, it is a good sign, this blinking is done by the firmware: when the firmware initializes it light-up both LEDs and when the USB port is enumerated the LEDs are switched off. This means that there is a firmware capable of USB communication running in the radio and the USB is apparently working.
1. Do you see the radio by typing "dmesg" just after inserting it and "lsusb", it should appear as "ID 1915:7777 Nordic Semiconductor ASA " in lsusb?
2. Why did you re-flash the radio? What firmware image did you use, a pre-built one or did you build it yourself?
Lama
Post by Lama » Mon Feb 26, 2018 8:38 am
Hi arnaud,
thank you for your answer.
1. Yes, and the Crazyradio is shown correctly as "D 1915:7777 Nordic Semiconductor ASA".
2. We thought it might be a Firmware Problem, so we tried to flash a new one. (Previous 0.53, and now again the 0.53).
Im just curious, because it´s the same error on two different PCs.
Thanks in advance for the help!
Greetings, Lama
Post by arnaud » Mon Feb 26, 2018 12:57 pm
Thanks for the precision. So it seems that the firmware is still communicating.
Are you using a hub or something in between the computer and the Crazyradio? Sometime they can cause problem.
For running directly on the host (not in the VM), have you created the udev rule to be able to use the client as normal users?
It would be interesting if you had the possibility of checking with another software than the client, for example can you try to connect with ROS to see if you get a similar error?
Lama
Post by Lama » Tue Feb 27, 2018 8:41 am
No, the Radio is connceted directly to the computer, without any hub. I also tried the front and rear USB-ports.
Yes, we created the rule when we first installed Ubuntu 16.04 LTS
We tried it with ROS, but with Ros, their is a different Error, with the message "The Process has died". We wanted to solve this problem last sunday, but then our crazyradio stopped working..
This Test with ROS was @ VM
Greetings
Lama
Lama
Post by Lama » Thu Mar 01, 2018 3:46 pm
Thank you for your help and suggestion. :)
Maybe i should mention that the VM and the "bare metal" Test are two different hosts.
VM runs on a Windows 7 64-bit host with VMware Player 14. VM is the Bitcraze VM (Xubuntu) upgraded to 16.04 LTS. ROS was upgraded to Kinetic also.
Bare-Metal is a Ubuntu 16.04 LTS with ROS Kinetic
cfclient and all firmware (LPS Nodes, Crazyflie, Crazyradio) is up to date.
Let me say that we are 2 Students relatively new to Linux. So maybe it is a problem with the Linux Host system too. :?
Following extracted from console at Bare-Metal machine with root privileges...
ROS throws the following error message:
[ERROR] [1519917445.314396970]: Exception thrown while processing service call: No matching USB Device with devid = 0 found!
[ERROR] [1519917445.352656081]: Service call failed: service [/add_crazyflie] responded with an error: No matching USB Device with devid = 0 found!
ROS:
... logging to /root/.ros/log/f07f1e14-1d65-11e8-9e65-90fba695ba33/roslaunch-cps-lab-01-8755.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
xacro.py is deprecated; please use xacro instead
started roslaunch server http://cps-lab-01:40159/
SUMMARY
PARAMETERS
 * /crazyflie/anchor0_pos: [3.5, 0.15, 0.16]
 * /crazyflie/anchor1_pos: [0.15, 0.15, 0.16]
 * /crazyflie/anchor2_pos: [1.675, 3.195, 0.16]
 * /crazyflie/anchor3_pos: [1.965, 0.155, 2....
 * /crazyflie/anchor4_pos: [0.17, 3.19, 2.125]
 * /crazyflie/anchor5_pos: [3.565, 3.195, 2....
 * /crazyflie/crazyflie_add/genericLogTopicFrequencies: [30, 30, 30]
 * /crazyflie/crazyflie_add/genericLogTopic_log_kfpos_Variables: ['kalman.stateX',...
 * /crazyflie/crazyflie_add/genericLogTopic_log_kfqt_Variables: ['kalman.q0', 'ka...
 * /crazyflie/crazyflie_add/genericLogTopic_log_ranges_Variables: ['ranging.distanc...
 * /crazyflie/crazyflie_add/genericLogTopics: ['log_kfpos', 'lo...
 * /crazyflie/crazyflie_add/tf_prefix: crazyflie
 * /crazyflie/crazyflie_add/uri: radio//0/90/2M
 * /crazyflie/joy/dev: /dev/input/js0
 * /crazyflie/joystick_controller/use_crazyflie_controller: True
 * /crazyflie/n_anchors: 6
 * /crazyflie/pose/name: goal
 * /crazyflie/pose/rate: 30
 * /crazyflie/pose/x: 2.0
 * /crazyflie/pose/y: 2.0
 * /crazyflie/pose/z: 1.7
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.12
NODES
  /crazyflie/
    controller_bridge (bitcraze_lps_estimator/crazyflie_controller_bridge.py)
    crazyflie_add (crazyflie_driver/crazyflie_add)
    joy (joy/joy_node)
    joystick_controller (crazyflie_demo/controller.py)
    log_range (bitcraze_lps_estimator/log_range.py)
    lps_efk_bridge (bitcraze_lps_estimator/lps_ekf_bridge.py)
    lps_viz (bitcraze_lps_estimator/lps_viz.py)
    pose (crazyflie_demo/publish_pose_teleop.py)
    crazyflie_server (crazyflie_driver/crazyflie_server)
    link1_broadcaster (tf/static_transform_publisher)
    rviz (rviz/rviz)
auto-starting new master
process[master]: started with pid [8768]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to f07f1e14-1d65-11e8-9e65-90fba695ba33
process[rosout-1]: started with pid [8781]
started core service [/rosout]
process[rviz-2]: started with pid [8798]
process[crazyflie/crazyflie_add-3]: started with pid [8799]
process[crazyflie/joy-4]: started with pid [8800]
process[crazyflie/joystick_controller-5]: started with pid [8808]
process[crazyflie/controller_bridge-6]: started with pid [8820]
process[crazyflie/pose-7]: started with pid [8827]
process[crazyflie/lps_efk_bridge-8]: started with pid [8830]
/root/catkin_ws/src/crazyflie_ros/crazyflie_demo/scripts/publish_pose_teleop.py:46: SyntaxWarning: name 'lastData' is assigned to before global declaration
  global lastData
process[crazyflie/lps_viz-9]: started with pid [8836]
[ INFO] [1519918430.808241887]: wait_for_service /add_crazyflie
process[crazyflie/log_range-10]: started with pid [8847]
[ INFO] [1519918430.813647634]: waitForService: Service [/add_crazyflie] has not been advertised, waiting...
process[link1_broadcaster-11]: started with pid [8849]
process[crazyflie_server-12]: started with pid [8857]
[ INFO] [1519918430.867193648]: Opened joystick: /dev/input/js0. deadzone_: 0.050000.
[ INFO] [1519918430.916112377]: waitForService: Service [/add_crazyflie] is now available.
[ INFO] [1519918430.916188013]: found /add_crazyflie
[ INFO] [1519918430.947871884]: Adding radio//0/90/2M as crazyflie with trim(0.000000, 0.000000). Logging: 1, Parameters: 1, Use ROS time: 1
[ERROR] [1519918430.965234561]: Exception thrown while processing service call: No matching USB Device with devid = 0 found!
[ERROR] [1519918431.005783078]: Service call failed: service [/add_crazyflie] responded with an error: No matching USB Device with devid = 0 found!
[crazyflie/crazyflie_add-3] process has finished cleanly
log file: /root/.ros/log/f07f1e14-1d65-11e8-9e65-90fba695ba33/crazyflie-crazyflie_add-3*.log
0x2b269e0 void QWindowPrivate::setTopLevelScreen(QScreen*, bool) ( QScreen(0x2121ef0) ): Attempt to set a screen on a child window.
0x2b1f0a0 void QWindowPrivate::setTopLevelScreen(QScreen*, bool) ( QScreen(0x2121ef0) ): Attempt to set a screen on a child window.
0x2b1e720 void QWindowPrivate::setTopLevelScreen(QScreen*, bool) ( QScreen(0x2121ef0) ): Attempt to set a screen on a child window.
0x2b1ce20 void QWindowPrivate::setTopLevelScreen(QScreen*, bool) ( QScreen(0x2121ef0) ): Attempt to set a screen on a child window.
cfclient:
INFO:cfclient.gui:Disabling STL printouts
INFO:cfclient.utils.input.inputreaders:Input readers: ['linuxjsdev', 'pysdl2']
INFO:cfclient.utils.input.inputreaders:Successfully initialized [linuxjsdev]
INFO:cfclient.utils.input.inputreaders:Could not initialize [pysdl2]: No SDL2 support on Linux
INFO:cfclient.utils.input.inputinterfaces:Found interfaces: ['leapmotion', 'wiimote', 'zmqpull']
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [leapmotion]: Leap Motion library probably not installed (No module named 'leapsdk')
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [wiimote]: Missing cwiid (wiimote) driver No module named 'cwiid'
INFO:cfclient.utils.config:Dist config read from /root/bitcraze/crazyflie-clients-python/src/cfclient/configs/config.json
INFO:cfclient.utils.config:Config file read from [/root/.config/cfclient/config.json]
INFO:cfclient.utils.input.inputinterfaces:Could not initialize [zmqpull]: ZMQ input disabled in config file
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
INFO:cfclient.utils.zmq_param:Biding ZMQ for parameters at tcp://*:1213
INFO:cfclient.utils.zmq_led_driver:Biding ZMQ for LED driverat tcp://*:1214
===== 2018.03.01 16:03:20 =====
    self.set_channel(i)
    timeout))
INFO:cfclient.utils.input:Selected MUX: Normal
INFO:cfclient.ui.main:Role of Microsoft X-Box 360 pad is Device
INFO:cfclient.utils.input.mux:Adding device Microsoft X-Box 360 pad to MUX Normal
LSUSB shows the follwing:
Bus 002 Device 010: ID 1915:7777 Nordic Semiconductor ASA
Bus 002 Device 007: ID 045e:028e Microsoft Corp. Xbox360 Controller
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 001 Device 003: ID 04f2:0112 Chicony Electronics Co., Ltd KU-8933 Keyboard with PS/2 Mouse port
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg:
[   35.283628] usb 2-1.1: Product: Crazyradio PA USB Dongle
[   35.283629] usb 2-1.1: Manufacturer: Bitcraze
[   35.283630] usb 2-1.1: SerialNumber: 138ADF2151
[   86.511133] usb 2-1.1: USB disconnect, device number 3
[   86.733457] usb 2-1.1: new full-speed USB device number 4 using ehci-pci
[   86.845245] usb 2-1.1: New USB device found, idVendor=1915, idProduct=7777
[   86.845248] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[   86.845249] usb 2-1.1: Product: Crazyradio PA USB Dongle
[   86.845250] usb 2-1.1: Manufacturer: Bitcraze
[   86.845251] usb 2-1.1: SerialNumber: 138ADF2151
[  106.672775] perf: interrupt took too long (2511 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
[  107.469762] usb 2-1.2: new full-speed USB device number 5 using ehci-pci
[  107.583469] usb 2-1.2: New USB device found, idVendor=045e, idProduct=028e
[  107.583471] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  107.583472] usb 2-1.2: Product: Controller
[  107.583473] usb 2-1.2: Manufacturer: ©Microsoft Corporation
[  107.583474] usb 2-1.2: SerialNumber: 1015F9F
[  108.610912] input: Microsoft X-Box 360 pad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input15
[  108.611196] usbcore: registered new interface driver xpad
[  122.095149] usb 2-1.1: USB disconnect, device number 4
[  122.317840] usb 2-1.1: new full-speed USB device number 6 using ehci-pci
[  122.429506] usb 2-1.1: New USB device found, idVendor=1915, idProduct=7777
[  122.429509] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[  122.429510] usb 2-1.1: Product: Crazyradio PA USB Dongle
[  122.429511] usb 2-1.1: Manufacturer: Bitcraze
[  122.429512] usb 2-1.1: SerialNumber: 138ADF2151
[  194.543172] usb 2-1.1: USB disconnect, device number 6
[  195.311174] usb 2-1.2: USB disconnect, device number 5
[  195.313357] xpad 2-1.2:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
[  196.773317] usb 2-1.1: new full-speed USB device number 7 using ehci-pci
[  196.887127] usb 2-1.1: New USB device found, idVendor=045e, idProduct=028e
[  196.887130] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  196.887132] usb 2-1.1: Product: Controller
[  196.887133] usb 2-1.1: Manufacturer: ©Microsoft Corporation
[  196.887134] usb 2-1.1: SerialNumber: 1015F9F
[  196.887892] input: Microsoft X-Box 360 pad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input16
[  199.065377] usb 2-1.2: new full-speed USB device number 8 using ehci-pci
[  199.176754] usb 2-1.2: New USB device found, idVendor=1915, idProduct=7777
[  199.176757] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[  199.176759] usb 2-1.2: Product: Crazyradio PA USB Dongle
[  199.176760] usb 2-1.2: Manufacturer: Bitcraze
[  199.176761] usb 2-1.2: SerialNumber: 138ADF2151
[  212.372249] perf: interrupt took too long (3141 > 3138), lowering kernel.perf_event_max_sample_rate to 63500
[  219.835801] usb 2-1.2: USB disconnect, device number 8
[  223.641850] usb 2-1.2: new full-speed USB device number 9 using ehci-pci
[  223.753659] usb 2-1.2: New USB device found, idVendor=1915, idProduct=7777
[  223.753662] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[  223.753664] usb 2-1.2: Product: Crazyradio PA USB Dongle
[  223.753665] usb 2-1.2: Manufacturer: Bitcraze
[  223.753666] usb 2-1.2: SerialNumber: 138ADF2151
[  668.996042] perf: interrupt took too long (3931 > 3926), lowering kernel.perf_event_max_sample_rate to 50750
[  711.868084] usb 2-1.2: USB disconnect, device number 9
[  802.714728] usb 2-1.2: new full-speed USB device number 10 using ehci-pci
[  802.826285] usb 2-1.2: New USB device found, idVendor=1915, idProduct=7777
[  802.826290] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[  802.826293] usb 2-1.2: Product: Crazyradio PA USB Dongle
[  802.826296] usb 2-1.2: Manufacturer: Bitcraze
[  802.826298] usb 2-1.2: SerialNumber: 138ADF2151
[ 1401.097542] usb 2-1.2: Product: Crazyradio PA USB Dongle
[ 1401.097544] usb 2-1.2: Manufacturer: Bitcraze
[ 1401.097546] usb 2-1.2: SerialNumber: 138ADF2151
[ 1407.162662] [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe A FIFO underrun
[ 1407.162783] [drm:intel_pch_fifo_underrun_irq_handler [i915]] *ERROR* PCH transcoder A FIFO underrun
[ 1728.188981] usb 2-1.2: USB disconnect, device number 11
[ 1728.410292] usb 2-1.2: new full-speed USB device number 12 using ehci-pci
[ 1728.521649] usb 2-1.2: New USB device found, idVendor=1915, idProduct=7777
[ 1728.521653] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[ 1728.521656] usb 2-1.2: Product: Crazyradio PA USB Dongle
[ 1728.521659] usb 2-1.2: Manufacturer: Bitcraze
[ 1728.521661] usb 2-1.2: SerialNumber: 138ADF2151
[ 1795.516380] usb 2-1.2: USB disconnect, device number 12
[ 1795.740661] usb 2-1.2: new full-speed USB device number 13 using ehci-pci
[ 1795.852505] usb 2-1.2: New USB device found, idVendor=1915, idProduct=7777
[ 1795.852508] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=29
[ 1795.852510] usb 2-1.2: Product: Crazyradio PA USB Dongle
[ 1795.852511] usb 2-1.2: Manufacturer: Bitcraze
[ 1795.852512] usb 2-1.2: SerialNumber: 138ADF2151
We couldnt figure out what causes the error. :?:
Next step is possible a reinstall of the environment. We will test with a new downloaded Bitcraze VM without any adjustments this sunday.
But still i think it is strange that this error happens @ Bare-Metal machine and Bitcraze VM.
For me it looks like we have bad luck and are the first ones to broke the crazyradio :D
Thank you for your answer.
Greetings
Lama
Re: [Ubuntu 16.04 LTS 64-bit] Crazyradio possibly broken, USB Error 32 (pipe Error) in cfclient
Post by arnaud » Fri Mar 02, 2018 10:02 am
Do you by any chance have another Crazyradio accessible somewhere (maybe someone else using Crazyflie at the university)?
Did you try using the windows client by installing the USB driver with Zadig?
Thanks a lot for all the logs, there is something that looks very fishy in dmesg about interrupts taking too long.
If your Sunday test does not work and if you cannot get access to another Crazyradio please drop a mail at support _at_ bitcraze.io, we will fix a replacement.
Lama
Post by Lama » Fri Mar 02, 2018 1:30 pm
Hello arnaud and thanks for the reply.
Sadly, we are the only one using crazyflie at the university at the moment, more precisely we have the only equipment.
The equipment contents: 4 Crazyflie, 1 Crazyradio PA, 1 XBOX Controller, 8 LPS Nodes, 1 Debugadapter, 4 LPS Decks.
So no we can't use another Crazyradio.
We tried with Zadig for a first touch but get some python errors, have to take a closer look at this aswell.
We will inform the professor, if our sunday tests fail. He is the one in responsibility for the equipment and can trigger the replacement.
We will let you know how sunday is going.
Greetings
Lama
Lama
Post by Lama » Sun Mar 04, 2018 3:42 pm
Hello arnaud,
we have tested the crazyradio at a new VM (on same host as the other) and reinstalled the bare-metal host.
Sadly the tests performed as expected. We assume now that the Crazyradio is definitly broken.
Thank you for your help and suggestions.
Greetings
Lama
Post by arnaud » Mon Mar 05, 2018 12:05 pm
That is sad. Please drop us an email and we will arrange a replacement.
