Crazyflie not turning on, on/off power button
thetinyquad
Post by thetinyquad » Tue Dec 19, 2017 8:58 am
Hi Guys,
Just assembled my crazyflie via setup steps. I keep pushing the on/off button with my finger but it doesn't turn on. Wondering if I'm just not pushing it correctly? When I connected it to the USB, two of the opposite diagonal propellers will spin and then stop, so I assume it's working.
Jens_Lee
Re: Crazyflie not turning on, on/off power button
Post by Jens_Lee » Tue Dec 19, 2017 12:56 pm
Hi thetinyquad
I experienced what sounds like the same behaviour, once i plugged in the usb, while having my battery disconnected.
Are you sure that your battery is connected and that it's charged?
thetinyquad
Post by thetinyquad » Wed Dec 20, 2017 12:07 am
Hi, thanks for the help!
Charged it for about 45 minutes today but still didn't turn on. The battery was connected to the PCB when charging.
I did find this thread though:
viewtopic.php?f=5&t=2492&p=12556&hilit= ... ery#p12790
Multimeter doesn't show a reading so seems to be a dead battery. I will contact support.
Post by tobias » Wed Dec 20, 2017 7:51 am
The battery PCM circuit has most likely gone into under-voltage protection mode. Normally it should exit this mode when charging is applied to it. As a first step let it charge for a full day and hopefully the battery charger on the CF2 can wake it up.
