Can't connect to CrazyRadio: "No backend available"
Jens_Lee
Post by Jens_Lee » Sun Nov 19, 2017 8:23 pm
Hi
I'm a happy new owner of a CF and butt while I was messing around with it tonight, it the CFClient suddenly stopped being able to connect. The prompt gives me when i scan:
WARNING:cflib.crtp.usbdriver:Exception while scanning for Crazyflie USB: No backend available
I'm on Win10, running the dongle with libusb-win32 and running the newest client, 2017.06.
It works in the WM, so it's def. not a hardware problem.
I've tried reinstalling the drivers, and reinstalling the client.
I was in the middle of installing Miniconda when it broke, but can't figure why that would be a problem?
Gonna try and mess around some more, but if anyone has suggestions, that would be awesome.
/Jens
Jens_Lee
Re: Can't connect to CrazyRadio: "No backend available"
Post by Jens_Lee » Sun Nov 19, 2017 9:39 pm
Just tried running the client from source, same result.
Post by arnaud » Fri Nov 24, 2017 10:32 am
You could try to install the libUSBK driver instead of libusb32, sometime it has worked better.
If it broke when installing miniconda it could be that you broke the pyusb installation. You can maybe try to run it in a new fresh miniconda environment. You can also try to completely remove the driver from the device manager and re-install it.
Jens_Lee
Post by Jens_Lee » Fri Nov 24, 2017 12:01 pm
Hi Arnaud, thanks for getting back.
I tries the libUSBK driver already, but that didn't change anything. The same for completely removing via device manager.
pip uninstalled and reinstalled aswell.
Going to try running in a new miniconda environment!
In the mean time I can work on the VM and i have a dedicated ubuntu laptop aswell. So it's no emergency.
