[SOLVED]crazyflie 2.0 m1 and m4 lights solid red, m2 solid blue
ben
Post by ben » Fri Jun 30, 2017 7:03 pm
So I was trying to fix a problem with a crazyflie 2.0 and a z-ranger deck that I know works because I've tested it on other crazyflies, and i decided to use the cold boot and flash the firmware a few times to see if that would help. The first time I flashed the firmware the M2 light was solid blue, but i'd experienced that before so I held in the button BEFORE plugging in the battery, then released when it went into bootloader mode. I did this twice - it never restarted perfectly for me - and then the last time I did it the two front lights - M1 and M4 - went solid red, while the M2 light stayed solid blue. However, this time it can at least turn off, so there's that. Anybody have any ideas? in the meantime i'm going to try and flash the firmware again.
Edit: I'd like to clarify; this was a Crazyflie 2.0, and I was using the firmware version 2017.06. I know the crazyradio PA works because it's how I got the firmware on before I tried to flash it. I know the z-ranger deck works because i've used it on other crazyflie 2.0s before.
Re: crazyflie 2.0 m1 and m4 lights solid red, m2 solid blue
Post by tobias » Mon Jul 03, 2017 9:33 am
If the M1 and M2 goes on solid red it is a hard fault. Could be because of a badly flashed/wrong FW or a bug. Aren't you able to get the offical FW back on?
ben
Post by ben » Wed Jul 05, 2017 6:21 pm
It went back into bootloader mode and after flashing it a few times it stopped.
Re: [SOLVED]crazyflie 2.0 m1 and m4 lights solid red, m2 solid blue
Post by arnaud » Thu Jul 06, 2017 9:30 am
Do you mean that it stopped not working? So it now works?
