Crazyflie dropps connection with "too many packages lost"
Posted: Sun May 14, 2017 9:56 pm
Hi there!
I have a crazyflie2.0 and crazyradio PA. Just received them a few days ago and started facing the problems, which are described below, already at the very beginning.
I keep losing the connection to my crazyflie2.0 each time after a few seconds after the connection is established. Usually the error "too many packages lost" is thrown.
It usually takes several trials even to connect to the crazyflie. The connection search sometimes does not recognize any available channels.
I tried the following ways:
-connect through all different available channels to the crazyflie -> always the same behaviour: no connection or dropping it after a few seconds.
-tried it having the crazyflie close to the crazyradio PA -> no changes
-tried to run the VM on Ubuntu14.04, Windows 7 and Windows 10. Always the same behaviour.
-Bootloaded the latest firmware on the crazyflie -> no changes
-Run the Android App: First established the connection nicely a few times (2-3) and then started to show the same behaviour - losing control after a few seconds or not being able to connect. But overall the Android App is more stable than through crazyradio PA.
-Run the crazyflie client on Ubuntu14.04 itself, no changes in behaviour.
-Run the ramp.py example code. Same behaviour: Losing connection After a few seconds or doesn't even connect.
Further information:
-After connection to the crazyflie (if succeeded) the telemetry data form the IMU ist in most (90%) cases not sent - or at least not shown in the GUI. It does read initially the parameters from the crazyflie (I can see them in the list on the gui) - but no further data is received and no further data is sent, e.g. control signals from my PS3 controller.
-If telemetry data is sent and shown on the gui - it's not updating smoothly but jerking.
-There is only 1 Wifi around in my testarea, switching this off did not make any difference.
-Self-test of crazyflie works fine.
-Never crashed the crazyflie, cant find defects by visual inspection.
Any help is greatly appreciated. Currently don't know how to proceed.
