Self-test failed out of box. M2 and M3 are solid blue. M1 is blinking red (constant) and M4 is silent.
How can I fix this issue? Thanks!
see vine.
https://vine.co/v/5wLQ3jlxwIl
self-test failed out of box
Re: self-test failed out of box
This does mean that the sensor are calibrated and the Crazyflie is ready to go. See first vine on this page: https://www.bitcraze.io/getting-started ... yflie-2-0/
Have you tried connecting the Crazyflie with a client?
Thanks! I realized this shortly after having it plugged in for a bit. I think the battery needed charge because after the initial sequence the lights dimmed and only M2 could be seen.
