CFclient on Ubuntu
hyperglider
CFclient on Ubuntu
Post by hyperglider » Sun Sep 25, 2016 1:11 am
Being trying to work out how to get the CFclient on Ubuntu. Is there a way to do this?
HG
whoenig
Re: CFclient on Ubuntu
Post by whoenig » Sun Sep 25, 2016 8:59 pm
goe
Post by goe » Mon Nov 28, 2016 2:40 am
Any chance these will be updated for Ubuntu 16.10 in the near future?
With PyQt4 QtWebKit being dropped, I've tried updating the client to PyQt5 and mostly muddled through QtWidgets vs QtGui sorting in the new version but still ran into issues with hexspinbox.py QAbstractSpinBox wrong argument types and got stuck there.
Post by arnaud » Mon Nov 28, 2016 7:56 am
There is a ticket about porting to QT5 and some preliminary code for it on github: https://github.com/bitcraze/crazyflie-c ... issues/269
It was aimed at Mac OS but from what you are saying I guess all OS would be better off with QT5 ...
As for webkit, it is needed only for the Tab which is not working anyway, lets disable it for now.
Post by arnaud » Mon Nov 28, 2016 8:04 am
Done, I just disabled the GPS tab. Please tell me if it helps running on Ubuntu 16.10.
Edited: typo 16.04 to 16.10 ...
goe
Post by goe » Tue Nov 29, 2016 6:33 am
Yes, that seems to have done the trick now and cfclient launches fine, connects and so on. I had to remove PySide as well since it was causing problems and was an unsuccessful attempt to get PyQt4 on Ubuntu 16.10 before deciding to just try moving to qt5.
I cloned your qt5 branch and repeated your same commenting out of ui tab for GPS manually:
https://github.com/ataffanel/crazyflie- ... n/tree/qt5
