Crazyflie 1.0 and firmware > 2015.1
Hovy
Post by Hovy »
Hello all,
I can not use on my Crazyflie 1.0 a firmware higher than 2015.1!
After flashing a higher version the LED's are on, but he does not respond to inputs.
I use the client version "Cfclient 2015.08", the last installer version.
The logfile after flashing "crazyflie1-2015.1.bin", everything works fine:
SYS: Build 0:02dd0d49962c (2015.1) CLEAN
SYS: I am 0x8712173654568549670FF50 and I have 128KB of flash!
MPU6050: Self test [OK].
HMC5883L: Self test [OK].
MS5611: Self test [OK].
The logfile after flashing "crazyflie1-2015.08.1.bin", no response to inputs:
SYS: Crazyflie 1.0 is up and running!
SYS: Build 0:61e23e51d7d3 (2015.08.1) CLEAN
CFGBLK: v0, verification [OK]
SYS: The system resumed after watchdog timeout [WARNING]
The logfile after flashing "cf1-2016.02.bin", no response to inputs:
SYS: Build NA:NA (2016.02) CLEAN
SYS: No assert information found
Please help me, what can I do?
Regards
Georg
Re: Crazyflie 1.0 and firmware > 2015.1
Post by chad »
Hi Georg,
This is quite possibly a problem with older client and newer firmware. I will try on my CF1 when I have a chance but have you tried using the latest client with the newest firmware?
Hovy
Post by Hovy »
Hi Chad,
thanks for your help, I will test it on the weekend.
How do I install the update?
Unzip and copy over the old files?
Georg
Hovy
Post by Hovy »
Hello all,
I have now testet with the Client version "Cfclient 2016.02" under Windows 10.
And it does not run! :?
What I noticed is, the battery state will not be indicated.
Here the output in the log file:
IMU: MPU6050 I2C connection [OIMU: HMC5883 I2C connection [OK].
cf1-2016.02.bin
nd
With version "crazyflie1-2015.1.bin" everything runs without problems!
What can I do?
Regards
Georg
otto
Post by otto »
I am experiencing the same issue
Post by chad »
Hi @otto,
What client and firmware versions do you have? I have confirmed that:
client: 2016.4
and
firmware: 2016.02
work fine together without this issue...
