Forum guidelines
Forum guidelines
Welcome to the Crazyradio support forum!
This is the right place to come if you are having any issues that you need help with. These issues may be software/firmware/mechanical/hardware related or any mix of these. To make it a bit easier for everyone to see which issues are solved and which still needs attention, there's a few guidelines to follow:
1) Only one issue per thread: Start a new thread for each new issue, even if you happen to have multiple issues at the moment. If you think that the issues are related then you can keep them in the same thread.
2) Don't bring up new issues in existing threads: Unless you are experiencing the same issue as already posted in a thread, start a new one.
3) Avoid duplicates: Use the search function and have a look at some of the subjects already in the forum. You questions might already have been answered.
4) Think of a good name for your thread: This is connected to (3). With good names it's easier to find what issues there are.
5) Rename thread to include [SOLVED] or [NOT SOLVABLE]: When you are happy with the support and the issue has been fixed then please rename the thread to include the prefix [SOLVED]. If it's an issue that can't or won't be solved then include the prefix [NOT SOLVABLE].
6) Report bugs: If you know you have found a bug it's better to report it on the Crazyradio Bitcucket tracker than to post it here.
Anything missing or unclear? Give us feedback :-)
/The team at Bitcraze
