having read the readme of the magnetometer of calibration (as proposed by Anton Krasovsky) the first thing I thought was that I don't want to go through the pain of installing Java and Processing. So I did a little search and sailboat people come to the help:
https://sites.google.com/site/sailboati ... ementation
I already have tested it, and it works great. Usage is actually pretty simple. Just put the raw values (as they come from the magnetometer) into a file called mag.txt, call Magneto (it's pretty simple to compile the c source) and it will display the necessary values needed for calibration. To use them one just need a vector addition and a simple matrix x vector multiplication (Magneto will display a ready to use matrix, no need to calc the inverse).
Works pretty good and is really easy to use (at least compared with the stuff which uses Processing).
What's left is to add some calibration in regard to the motor power (I've seen the heading changes a few degree when the motors are powered).
Have fun,
Alexander Holler
PS: Using Magneto to calibrate the accelerometer values can be done too, but I have to read a bit more about that.
Easy magnetometer calibration
Re: Easy magnetometer calibration
When you say it works great what do you mean?aholler wrote: I already have tested it, and it works great. Usage is actually pretty simple. Just put the raw values (as they come from the magnetometer) into a file called mag.txt, call Magneto (it's pretty simple to compile the c source) and it will display the necessary values needed for calibration. To use them one just need a vector addition and a simple matrix x vector multiplication (Magneto will display a ready to use matrix, no need to calc the inverse).
Why not do the calibration in real time on the crazyflie itself?
You can get the code for AHRS from here - it looks very similar to the code in senfusion6.caholler wrote:PS: Using Magneto to calibrate the accelerometer values can be done too, but I have to read a bit more about that.
http://www.x-io.co.uk/open-source-imu-a ... lgorithms/
That the calibrated values are looking fine afterwards and are directly usable to calculate the heading.Dave wrote:When you say it works great what do you mean?
The amount of available (free) RAM isn't enough. You need to collect a bunch of values and you need additional RAM for the calculations too. Don't forget, the crazyflie only has 20kb RAM. To give you some values, the files with values I've produced for calibration are having about 1000 lines, each with 3 values. That already makes about 6kb, just for the collected values.Dave wrote:Why not do the calibration in real time on the crazyflie itself?
With some fiddling it might be be possible (e.g. reusing large parts of the RAM just for the calibration phase), but ...
I didn't speak about using a 9-axis sensor fusion algorithm, but about calibrating the accelerometer values too. I'm not sure if it would make a difference when calibrated accelerometer values are used, but maybe.Dave wrote:You can get the code for AHRS from here - it looks very similar to the code in senfusion6.caholler wrote:PS: Using Magneto to calibrate the accelerometer values can be done too, but I have to read a bit more about that.
Of course, using a 9-axis sensor fusion algorithm is something I want to test too, but I assume first some additional correction is needed to get rid of the influence of the motor power on the magnetometer values. As said, the magnetometer values still do change when the motors are powered (the calibration is made for a static environment) . I'm not sure if the changing values (through motor power) will really influence the fusion algorithm, but that needs testing (and spare time ).
Alexander Holler
