For those wanting to add a Camera: TX back in stock
omwdunkley
Post by omwdunkley » Tue Aug 13, 2013 5:45 pm
Hey guys,
Im not affiliated to fpv-hobby in anyway but I just wanted to advise you that their micro transmitter is back in stock: http://www.fpvhobby.com/180-4-ghz-nano-size-vtx.html Ive just ordered one:)
Voltage: 3.3 - 5.5 Volts (youll need a step up voltage regulator, first results indicated that stepping up to ~5v is best)
Current: 42 mA
Weight: 0.3g
Freq: 2.370Ghz
I have not actually used that one before, but others have had experience with it. You'll also need some other components, see the following posts:
http://forum.bitcraze.se/viewtopic.php?f=6&t=491 - How I got my cam working (with a 5.8ghz tx - should also work with the 2.4ghz tx)
http://forum.bitcraze.se/viewtopic.php? ... t=30#p3191 - How SuperRoach got his working (same transmitter as linked above)
http://forum.bitcraze.se/viewtopic.php? ... t=20#p3079 - jtang613 also got his working (not sure with which transmitter)
If anybody knows any other stores that sell similar hardware, please share!
