Debugging crazyflie
Headhunter
Debugging crazyflie
Post by Headhunter »
Which pin connections are required between st link v2 and crazyflie debug adapter in order to debug crazyflie?
Re: Debugging crazyflie
the SWD lines and reset are required, SWO can be connected if you want to use ITM. This means:
- GND
- VCC
- SWIO
- SWCLK
- SWO (Optional)
- RESET
That corresponds to the connector P3 of the Crazyflie schematic: https://www.bitcraze.io/documentation/h ... _rev.b.pdf
Headhunter
Voltage of VCC?
SWIO means SWDIO?
The Crazyflie is a 3.0V system. Yes SWIO is SWDIO, its a typo in the schematic.
