creating a new autopilot mode and switching between autopilot mode and manual control
Horace20
Post by Horace20 »
Hi Sir/ Madam,
I am a beginner in programming crazyflie. I have a few questions as follows:
1. May I know where and how could I create a new autopilot mode and write my own algorithm/code on it?
2. since the algorithm needs to be tested, I also would like to know whether I could switch between the new mode and existing manual control (using a joypad) for safety reasons.
3. can I use the crazyflie PC client to display some real-time sensor data/ plots, while executing the autopilot mode?
It would be greatly appreciated if you could provide an example code or show me some existing codes that I could refer.
Thank you very much.
wydmynd
Re: creating a new autopilot mode and switching between autopilot mode and manual control
Post by wydmynd »
I am not an expert, but regarding section 1 , this question has been answered few times already, search for "push demo" in the search box
regarding section 2, I can say in the function SetHoverSetpoint there is a priority parameter.
I think the remote control commands are sent in priority 3 out of 6
if your autopilot sends commands with a lower/higher priority (2 or 4 for example), this will allow the commander module to prioritize the setpoint correctly.
I ended up using a parameter to update the autopilot priority when I want to take over, so it can also return to back autopilot smoothly
