Hi all,
I've read thru some of the developer documentation and searched this forum and found some hits on Java but can't determine whether Java can be used in the planning/controlling subsystems. I'd like to use this copter to help teach Computer Science I students in Java. Appropriate or should I look elsewhere?
What subsytems can Java be used?
Re: What subsytems can Java be used?
The java library (https://github.com/fredg02/se.bitcraze.crazyflie.lib) is maintained by Fred (fredg02 on github). I'm not sure of the current status, you should probably check with him.
Thanks, I appreciate the information.
