Modifying usbLinkTask causing queue error
sammy-qq
Post by sammy-qq »
I'm trying to modify the usbLinkTask and create a custom parsing function for incoming USB packets so that I can control the Crazyflie solely using USB.
Originally I had modified sysLinkTask to read from USB instead of from the radio chip UART, like this:
/* Syslink task, handles communication between nrf and stm and dispatch messages
static USBPacket usbIn;
static void syslinkTask(void *param) {
  SyslinkPacket slp;
  while (1) {
      /*ORIGINAL
     //get an incoming radio packet (blocking fxn), read it into slp
      uartslkGetPacketBlocking(&slp);
      syslinkRouteIncommingPacket(&slp);
     //MY VERSION
      usbGetDataBlocking(&usbIn);
      if (!usbSlkParseIncomingPacket(&slp) {
             //incoming packet is now in slp
            //route the packet to the appropriate location
      else {
            //DEBUG_PRINT something
So I wrote a new parsing function called usbSlkParseIncomingPacket, modified the syslinkRouteIncommingPacket() function and some other functions a bit, pushed the setpoints to the controller, modified the Crazyflie Android client, created a fake temporary ack that the Crazyflie would send back over USB...then I plugged an Android into the Crazyflie, and it worked: I was able to send basic control packets to the Crazyflie over USB and control the motors that way.
I want to keep the original syslink, though, and just modify the usbLinkTask to accept my control packets. But I'm running into a problem.
This is what I'm trying to do in usbLinkTask:
//static CRTPPacket p;
static void usblinkTask(void *param) {
	SyslinkPacket slp;
  while (1) {
	//ORIGINAL
	// Fetch a USB packet off the queue
	p.size = usbIn.size - 1;
	memcpy(&p.raw, usbIn.data, usbIn.size);
	// This queuing will copy a CRTP packet size from usbIn
	ASSERT(xQueueSend(crtpPacketDelivery, &p, 0) == pdTRUE);
	DEBUG_PRINT("Got some USB data\n");*/
	 //MY VERSION
	//DEBUG_PRINT("USB data read in successfully\n");
	//DEBUG_PRINT("Read in data %c, now sending...\n", usbIn.data[0]);
	//data[0] = 0x30;
	//usbSendData(1, data);
	//DEBUG_PRINT("USB send complete\n");
	//if the packet looks valid
	if (!usbslkParseIncomingPacket(&slp)) {
		//DEBUG_PRINT("Parsed USB successfully, routing...\n");
		usblinkRouteIncomingPacket(&slp);
	//otherwise the parsing found invalidity, ignore this pkt and get the next incoming USB packet
	else {
	  DEBUG_PRINT("syslinkTask: parse failed, not routing the packet\n");
But for some reason, even when I just add the line "if (!usbslkParseIncomingPacket(&slp))", the Crazyflie crashes when I have the Android plugged in and start sending packets to the Crazyflie. This is what's going on if I just add the line "if (!usbslkParseIncomingPacket(&slp))", and comment out the rest of the code above: https://drive.google.com/file/d/1z00OPF ... sp=sharing
If I then comment out the line "usblinkRouteIncomingPacket(&slp);" as well, I get this: https://drive.google.com/file/d/1Tuazq7 ... sp=sharing, which is showing queue inexistent from within an ISR. So I'm guessing it has something to do with one of the functions in usb.c: either usbd_cf_DataIn() or usbd_cf_SOF()...any ideas?
I do see that usblinkTask is by default set up to create CRTP packets from the incoming USB data, but let's say I wanted to change the protocol of the packets and set up my own parser.
Thanks a lot!
Reason: Adding code blocks
Re: Modifying usbLinkTask causing queue error
Side note: I edited your message to add code blocks, it makes it much easier to read.
The FreeRTOS assert you are getting might actually comes from memory problem. We have seen it when a task would have its stack overflow. So the first debug advice I would have would be to increase the stack size of the task you are running in. Stack sizes are in config.h: https://github.com/bitcraze/crazyflie-f ... #L154-L184.
Beside that, I am curious as of why you are doing this? As you noted there is already CRTP over USB implemented and syslink is only used to control very platform-specific things like power management and radio settings. Since you are communicating from outside the Crazyflie why not stick to CRTP.
sammy-qq
Post by sammy-qq »
Thanks a lot for the response! I'm actually controlling the Crazyflie over Wifi Direct: one phone has the Android client open (modified) and streams packets over Wifi to another phone which is plugged into the drone via USB. CRTP is a little cumbersome to use (both for firmware and Android client) when there's no radio involved, so I'm testing my own basic packet protocol which is a slight modification of CRTP. Like I said, it worked in syslinkTask, but I'm baffled as to why it won't work in usblinkTask.
I did try changing the stack size as you said...that didn't seem to fix anything. Any other ideas?
I have new ideas abut what can go wrong but I have a proposal that could allow you to make your own protocol without modifying the low level packet handling:
You can use the "app channel" to transmit your packets in a CRTP packet. There is an API ready to use in the Crazyflie to send and receive packets through this channel, and on the application side you "just" need to prepend your packet with one byte (corresponding to the CRTP header) and when sending them to the Crazyflie and remove the header byte from the packets you receive. The CRTP header for app channel is 0xD3 so:
  • You send to the USB endpoint "0xD3 <payload>"
  • When you receive from the USB endpoint, you discard anything that does not start by 0xD3 and receive packets that have the form "0xD3 <payload>"
On the API side, there is an example showing how to send and receive packet from the app channel: https://github.com/bitcraze/crazyflie-f ... test.c#L35
