Running sample code
Posted: Tue Jul 23, 2013 3:26 pm
Hello.
I'm not programmer but I have some experience with visual Basic and C and this is my first contact with pyton.
I have tried unsuccesfully to run the following code that I have found in the wiki.
It should conect to the crazyflie and turn the motors on, but doesn't work.
This is the error report.
I have tried both under windows, and using the VM and the error reports i are similar
Could somebody tell me what is wrong?
import logging
import cflib.crtp
from cfclient.utils.logconfigreader import LogConfig
from cfclient.utils.logconfigreader import LogVariable
logging.basicConfig(level=logging.DEBUG)
class Main:
Class is required so that methods can access the object fields.
def __init__(self):
Connect to Crazyflie, initialize drivers and set up callback.
The callback takes care of logging the accelerometer values.
self.crazyflie = Crazyflie()
cflib.crtp.init_drivers()
self.crazyflie.connectSetupFinished.add_callback(
self.connectSetupFinished)
self.crazyflie.open_link("radio://0/10/250K")
def connectSetupFinished(self, linkURI):
Configure the logger to log accelerometer values and start recording.
The logging variables are added one after another to the logging
configuration. Then the configuration is used to create a log packet
which is cached on the Crazyflie. If the log packet is None, the
program exits. Otherwise the logging packet receives a callback when
it receives data, which prints the data from the logging packet's
data dictionary as logging info.
# Set accelerometer logging config
accel_log_conf = LogConfig("Accel", 10)
accel_log_conf.addVariable(LogVariable("acc.x", "float"))
accel_log_conf.addVariable(LogVariable("acc.y", "float"))
accel_log_conf.addVariable(LogVariable("acc.z", "float"))
# Now that the connection is established, start logging
self.accel_log = self.crazyflie.log.create_log_packet(accel_log_conf)
if self.accel_log is not None:
self.accel_log.dataReceived.add_callback(self.log_accel_data)
self.accel_log.start()
else:
print("acc.x/y/z not found in log TOC")
def log_accel_data(self, data):
logging.info("Accelerometer: x=%.2f, y=%.2f, z=%.2f" %
(data["acc.x"], data["acc.y"], data["acc.z"]))
Main()
Python 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> ================================ RESTART ================================
DEBUG:cflib.crazyflie:Adding callback on port [5] to [<bound method Log._new_packet_cb of <cflib.crazyflie.log.Log instance at 0x02458DA0>>]
DEBUG:cflib.crazyflie:Adding callback on port [0] to [<bound method Console.incoming of <cflib.crazyflie.console.Console instance at 0x028039E0>>]
DEBUG:cflib.crazyflie:Adding callback on port [2] to [<bound method _ParamUpdater._new_packet_cb of <_ParamUpdater(Thread-2, initial daemon)>>]
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/250K]
INFO:cflib.crazyflie:We are connected[radio://0/10/250K], request connection setup
DEBUG:cflib.crazyflie.toc:[5]: Start fetching...
DEBUG:cflib.crazyflie:Adding callback on port [5] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x02807170>>]
DEBUG:cflib.crazyflie:ExpectAnswer: Will expect answer on port [5]
>>> DEBUG:cflib.crazyflie:ExpectAnswer: No answer on [5], do retry
INFO:cflib.crazyflie:Callback->Connected to [radio://0/10/250K]
WARNING:cflib.crazyflie.log:Error no LogEntry to handle block=3
ERROR:cflib.crazyflie.toc:Got packet that was not on TOC channel, TOC fetch will probably not succeed
DEBUG:cflib.crazyflie:ExpectAnswer: Got answer back on port [5], cancelling timer
WARNING:cflib.crazyflie.log:Error no LogEntry to handle block=4
WARNING:cflib.crazyflie.log:Error no LogEntry to handle block=1
WARNING:cflib.crazyflie.log:Error no LogEntry to handle block=2
DEBUG:cflib.crazyflie.toc:[5]: Got TOC CRC, 9 items and crc=0x892049D2
DEBUG:cflib.crazyflie.toc:Requesting index 0 on port 5
WARNING:root:[5]: Was expecting 0 but got 9
DEBUG:cflib.crazyflie.toc:Added element [0]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 1
DEBUG:cflib.crazyflie.toc:Requesting index 1 on port 5
DEBUG:cflib.crazyflie.toc:Added element [1]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 2
DEBUG:cflib.crazyflie.toc:Requesting index 2 on port 5
DEBUG:cflib.crazyflie.toc:Added element [2]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 3
DEBUG:cflib.crazyflie.toc:Requesting index 3 on port 5
DEBUG:cflib.crazyflie.toc:Added element [3]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 4
DEBUG:cflib.crazyflie.toc:Requesting index 4 on port 5
DEBUG:cflib.crazyflie.toc:Added element [4]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 5
DEBUG:cflib.crazyflie.toc:Requesting index 5 on port 5
DEBUG:cflib.crazyflie.toc:Added element [5]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 6
DEBUG:cflib.crazyflie.toc:Requesting index 6 on port 5
DEBUG:cflib.crazyflie.toc:Added element [6]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 7
DEBUG:cflib.crazyflie.toc:Requesting index 7 on port 5
DEBUG:cflib.crazyflie.toc:Added element [7]
DEBUG:cflib.crazyflie.toc:[5]: More variables, requesting index 8
DEBUG:cflib.crazyflie.toc:Requesting index 8 on port 5
DEBUG:cflib.crazyflie.toc:Added element [8]
WARNING:cflib.crazyflie.toccache:Could not save cache, no writable directory
DEBUG:cflib.crazyflie:Removing callback on port [5] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x02807170>>]
DEBUG:cflib.crazyflie.toc:[5]: Done!
DEBUG:cflib.crazyflie.toc:[2]: Start fetching...
DEBUG:cflib.crazyflie:Adding callback on port [2] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x02825288>>]
DEBUG:cflib.crazyflie:ExpectAnswer: Will expect answer on port [2]
DEBUG:cflib.crazyflie:ExpectAnswer: Got answer back on port [2], cancelling timer
DEBUG:cflib.crazyflie.toc:[2]: Got TOC CRC, 27 items and crc=0x27A2C4BA
DEBUG:cflib.crazyflie.toc:Requesting index 0 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 1
DEBUG:cflib.crazyflie.toc:Requesting index 1 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 2
DEBUG:cflib.crazyflie.toc:Requesting index 2 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 3
DEBUG:cflib.crazyflie.toc:Requesting index 3 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 4
DEBUG:cflib.crazyflie.toc:Requesting index 4 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 5
DEBUG:cflib.crazyflie.toc:Requesting index 5 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 6
DEBUG:cflib.crazyflie.toc:Requesting index 6 on port 2
DEBUG:cflib.crazyflie:ExpectAnswer: No answer on [2], do retry
WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [2]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 7
DEBUG:cflib.crazyflie.toc:Requesting index 7 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 8
DEBUG:cflib.crazyflie.toc:Requesting index 8 on port 2
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 9
DEBUG:cflib.crazyflie.toc:Requesting index 9 on port 2
DEBUG:cflib.crazyflie.toc:Added element [9]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 10
DEBUG:cflib.crazyflie.toc:Requesting index 10 on port 2
DEBUG:cflib.crazyflie.toc:Added element [10]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 11
DEBUG:cflib.crazyflie.toc:Requesting index 11 on port 2
DEBUG:cflib.crazyflie.toc:Added element [11]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 12
DEBUG:cflib.crazyflie.toc:Requesting index 12 on port 2
DEBUG:cflib.crazyflie.toc:Added element [12]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 13
DEBUG:cflib.crazyflie.toc:Requesting index 13 on port 2
DEBUG:cflib.crazyflie.toc:Added element [13]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 14
DEBUG:cflib.crazyflie.toc:Requesting index 14 on port 2
DEBUG:cflib.crazyflie.toc:Added element [14]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 15
DEBUG:cflib.crazyflie.toc:Requesting index 15 on port 2
DEBUG:cflib.crazyflie.toc:Added element [15]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 16
DEBUG:cflib.crazyflie.toc:Requesting index 16 on port 2
DEBUG:cflib.crazyflie.toc:Added element [16]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 17
DEBUG:cflib.crazyflie.toc:Requesting index 17 on port 2
DEBUG:cflib.crazyflie.toc:Added element [17]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 18
DEBUG:cflib.crazyflie.toc:Requesting index 18 on port 2
DEBUG:cflib.crazyflie.toc:Added element [18]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 19
DEBUG:cflib.crazyflie.toc:Requesting index 19 on port 2
DEBUG:cflib.crazyflie.toc:Added element [19]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 20
DEBUG:cflib.crazyflie.toc:Requesting index 20 on port 2
DEBUG:cflib.crazyflie.toc:Added element [20]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 21
DEBUG:cflib.crazyflie.toc:Requesting index 21 on port 2
DEBUG:cflib.crazyflie.toc:Added element [21]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 22
DEBUG:cflib.crazyflie.toc:Requesting index 22 on port 2
DEBUG:cflib.crazyflie.toc:Added element [22]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 23
DEBUG:cflib.crazyflie.toc:Requesting index 23 on port 2
DEBUG:cflib.crazyflie.toc:Added element [23]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 24
DEBUG:cflib.crazyflie.toc:Requesting index 24 on port 2
DEBUG:cflib.crazyflie.toc:Added element [24]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 25
DEBUG:cflib.crazyflie.toc:Requesting index 25 on port 2
DEBUG:cflib.crazyflie.toc:Added element [25]
DEBUG:cflib.crazyflie.toc:[2]: More variables, requesting index 26
DEBUG:cflib.crazyflie.toc:Requesting index 26 on port 2
DEBUG:cflib.crazyflie.toc:Added element [26]
DEBUG:cflib.crazyflie:Removing callback on port [2] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x02825288>>]
DEBUG:cflib.crazyflie.toc:[2]: Done!
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K]
WARNING:cflib.crazyflie.toc:Unable to find variable [acc.x]
WARNING:cflib.crazyflie.log:Log: acc.x not in TOC, this block cannot be used!
