crazyflie's basic speed
JaeDeok
Post by JaeDeok »
I want to control the speed of crazyflie.
Can you set the default speed of Crazyflie's firmware?
Re: crazyflie's basic speed
Can you give a bit more context information about what you are trying to achieve, this way we will be able to point you in the right direction.
It is possible to control the Crazyflie in velocity, as long as it is using some kind of positioning system (ex. Flow deck, LPS, Lighthouse, mocap, etc...). There is no default velocity setup anywhere, the controller will try to follow the velocity setpoint.
