Is there any way the Crazyflie can be programmed to navigate a predefined obstacle course autonomously? For example, maybe it would fly and land on a certain location, and then it would proceed to go through a short tunnel, and so on.
If so what steps would be required to make it work?
What files would need to be modified?
New developer here. Please be descriptive with your answers, thank you!
						Obstacle Course
				SuperRoach
- Member
Re: Obstacle Course
Most importantly it would need to be aware of its current position to compensate for wind etc... which means a gps. It doesn't have one of those which makes automatic flight beyong using say the magnetometer to emulate hover very tricky.
						Re: Obstacle Course
We're planning to have the obstacle course indoors, and also we're trying to avoid using GPS. Is there anyway we can do it without the use of GPS.
Thanks for responding,
Ben
Ben
Re: Obstacle Course
Ben, most of the indoor tracking that I've seen for quadcopters have been in the way of computer vision, with a bunch of cameras mounted around a room. It's complex to setup, especially for one person. You'd have to give the cameras and a central computer a way of identifying the copter, either by markers on the copter or some other scheme. It's not trivial, but definitely doable, and I bet you might find a college that's done it with their source code openly available.
