[SOLVED] BasicLog example - maximum items in logConfig
wydmynd
Post by wydmynd »
I am trying to log about 20 variables over radio/USB ,
when trying to log over 6 items (float) in one logConf element or block , I get an error.
looking at log.py could not understand where the limit is originating from. the length of a log packet (30) ?
it is possible to add multiple log blocks in parallel , but seems like a strange solution.
Re: BasicLog example - maximum items in logConfig
The limit for one log block is 26 bytes. 6 floats is already 6 x 4 bytes = 24 bytes so if you add more floats you will indeed get issues. We do have an issue open about this since this already seem to happen at only 25 bytes, but 20 x 4 bytes is already way over the limit.
Your only solution is to add multiple log blocks in parallel. If you don't mind that the measurements of different log blocks are not exactly send at the same timestamp, that it should not be a problem. It is just the limitation of what a radio packet can send so unfortunately not much more that we can do about it.
wydmynd
Post by wydmynd »
OK thanks!
I suggest adding that to the documentation
Re: [SOLVED] BasicLog example - maximum items in logConfig
Yes I agree it should be in the documentation. I will add it there soon!
Calvin Chua
Post by Calvin Chua »
Hi, is there any sample code or tutorial on parallel logging please?
See this post for an example viewtopic.php?f=11&t=4450
wydmynd
Post by wydmynd »
Hi, so in light of recent updates to the logging code in cflib, just wanted to make sure that synclogger is the only way (or recommended way) to log a large amount of variables at once?
didn't exactly understand the improvement in the logging functionality .
