Max thrust value?
Posted: Wed Jul 17, 2013 12:00 am
To quote myself from http://forum.bitcraze.se/viewtopic.php? ... t=30#p2820:
Which is the correct maximum thrust value? The one in the wiki or the one in the source code?
Regards,
Fred
However in FlightTab.py in the Crazyflie PC client I found:Looking through the wiki again, I found the following line, which probably explains the reason:
"Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power)."
-> http://wiki.bitcraze.se/projects:crazyf ... l_commands
MAX_THRUST = 65365.0
Regards,
Fred
