Unpack requires a buffer of 4 bytes
GIduarte
Post by GIduarte »
Hello, I have a problem.
I want to receive by log block this values:
  • rateYaw
  • rateRoll
  • ratePitch
  • pitch
  • roll
  • vx
  • vy
  • vz
  • quat
  • batteryLevel
So I use basiclog.py and replace :
	self._lg_stab.add_variable('stabilizer.roll', 'float')
        self._lg_stab.add_variable('stabilizer.pitch', 'float')
        self._lg_stab.add_variable('stabilizer.yaw', 'float')
by
	self._lg_stab.add_variable('pm.batteryLevel', 'uint8_t')
        self._lg_stab.add_variable('stateEstimateZ.quat', 'uint32_t')
        self._lg_stab.add_variable('stateEstimateZ.vx', 'int16_t')
        self._lg_stab.add_variable('stateEstimateZ.vy', 'int16_t')
        self._lg_stab.add_variable('stateEstimateZ.vz', 'int16_t')
        self._lg_stab.add_variable('stateEstimateZ.rateYaw', 'int16_t')
        self._lg_stab.add_variable('stateEstimateZ.rateRoll', 'int16_t')
        self._lg_stab.add_variable('stateEstimateZ.ratePitch', 'int16_t')
        self._lg_stab.add_variable('stateEstimate.pitch', 'float')
        self._lg_stab.add_variable('stateEstimate.roll', 'float')
But I have this error:
File "/home/bitcraze/.local/lib/python3.6/site-packages/cflib/crazyflie/__init__.py", line 396, in run
cb.callback(pk)
File "/home/bitcraze/.local/lib/python3.6/site-packages/cflib/crazyflie/log.py", line 580, in _new_packet_cb
block.unpack_log_data(logdata, timestamp)
File "/home/bitcraze/.local/lib/python3.6/site-packages/cflib/crazyflie/log.py", line 307, in unpack_log_data
unpackstring, log_data[data_index:data_index + size])[0]
struct.error: unpack requires a buffer of 4 bytes
I tried into client too, but although the program accepted, the file in which the log block was written contained only the header.
Does anyone have any suggestions??
Re: Unpack requires a buffer of 4 bytes
Post by kristoffer »
There is a limit to how many log variables that can be addd to one block, the total size must be max 26 bytes. Unfortunately the error reporting is not stellar for this...
You simply have to use two log blocks instead.
If you are using the SyncLogger class, you can pass in an array of log blocks.
GIduarte
Post by GIduarte »
Hi, thanks for the reply.
I readed about the limit of 26 bytes per block.
But, 1 (uint8_t) + 4 (uint32_t) + 6 x 2 (int16_t) + 2 x 4 (float) = 25 bytes, which is below the limit ...
You are right, my bad! I created an issue https://github.com/bitcraze/crazyflie-l ... issues/164 for it.
It seems to work if you remove one of the variables in the log config, a work around may be to use two log blocks instead.
