Mellinger controller on Python
Re: Mellinger controller on Python
Post by kristoffer » Mon May 11, 2020 12:14 pm
Yes, the problem you see is because CLOAD=0, in your case it should be 1.
CLOAD is actually not a good setting to be used as an example since it is rarely changed, I will update the docs. Sorry for the confusion!
Your config.mk file should probably be something like:
PLATFORM=CF2
# DEBUG is optional, will give a bigger binary that takes longer to flash
#DEBUG=1
# CLOAD should be 1 in most normal use cases. 1 is also the default value, so there is no need to set it here
#CLOAD=1
# Enable this to force the mellinger controller to be used
# CONTROLLER=Mellinger
To create my controller, I just add a line with my file name in the same folders as the others controllers files?
or how can I add my controller to the firmware?
You need to:
1. Add the file in the same folder as the other controllers. Let's call it eduardoController.c
2. Add it in the make file, for instance on this line https://github.com/bitcraze/crazyflie-f ... efile#L174 Note the name here should be eduardoController.o
3. Add a new entry in the enum after the INDI controller (for instance ControllerTypeEduardo), https://github.com/bitcraze/crazyflie-f ... ller.h#L35
After that you are good to go (I think :-))
You can activate your controller by setting the
stabilizer.controller
to 4, in runtime,
or force it in the make config with
CONTROLLER=Eduardo
I saw some .o files in crazyflie-firmware/bin that I don't know how they are created, could you help me ??
This is how make works. A Makefile describes what we want, for instance some object files (*.o). Somewhere else in the Makefile there is a description of how to produce an object file by compiling a C file. When make is running it will see that there is an .o file missing and it will try find the corresponding C file to compile it. You can read more about make here https://en.wikipedia.org/wiki/Make_(software)
EduardoAguilar
Post by EduardoAguilar » Wed May 13, 2020 4:22 pm
Hi Kristoffer thank you for the answer.
No problem all its okay.
I have my controller already upload on the firmware, but I have some warnings on my code, are conversions float to double, I'm correcting it.
I have some questions, can you help me?
1. When I used the eduardo Controller on cflib will i select '4' for use my controller?
2. I don't understand this part to change the controller, Will i just write the next command in the other terminar?
Post by kimberly » Thu May 14, 2020 10:58 am
stabilizer.controller is a parameter value. Please check the documentation on how to set this from the cflib: https://www.bitcraze.io/documentation/r ... rameters-1
EduardoAguilar
Post by EduardoAguilar » Thu May 14, 2020 3:19 pm
Thank you Kimberly I wiil check the documentation.
