Read control inputs from mobile application
volmen3
Re: Read control inputs from mobile application
Post by volmen3 » Thu Feb 13, 2020 4:03 pm
I will look at it also myself more carefully and will make an update.
But just to doublecheck, in a normal use the Assist Mode must be activated while you hold corresponding button, right? Because, as I wrote, in Position Hold mode I see the setpoint->velocity values change only while holding the Assist Mode button. If I release it, setpoint->roll, pitch, yawRate, thrust are sended.
Thank you for the respond and best regards.a
Post by kimberly » Fri Feb 14, 2020 9:13 am
Yes my bad, indeed you would need to hold the button. But than this is an actual issue and needs to be fixed soon. I will make an issue in the client repo about this. Thanks for letting us know!
Btw, could it maybe also be related to this issue ? https://github.com/bitcraze/crazyflie-c ... issues/388
