Mechanical design files
Posted: Tue Dec 03, 2019 7:26 pm
A quick cursory search has indicated to me that you have chosen not to publish the PCB files (is this true?)
If so, is there any way to get a mechanical drawing file other than via measuring the Crazyflie I own (or printing the component placement file to scale)? At this point it is faster for me to have just measured the device, but I think that it would be quite helpful to others to publish an electronic version with physical dimensions (as well as how the various decks fit and occupy the space around the Crazyflie).
Thank you.
Thank you.
