Generate and upload trajectories in real time
Oliver
Post by Oliver » Tue Nov 19, 2019 3:01 am
Hello everyone,
I 'm working on a project that make the crazyflie track a complex trajectory. The waypoints of the trajectory changes randomly, and the position of the crazyflie and waypoints can be captured by the Optitrack, so to make the crazyflie track this changing trajectory, we need to generate and upload trajectory in real time. The way of generating trajectory is the same as the paper "Minimum Snap Trajectory Generation and Control for Quadrotors" by mellinger.
The problem is that I don't know how to re-upload several trajectories generated by computer during the crazyflie's flight.
I'm using optitrack and crazyswarm ros package, the controller I used is mellinger controller.
Does someone have some experience or information about ?
Thank you all!
whoenig
Re: Generate and upload trajectories in real time
Post by whoenig » Tue Nov 19, 2019 6:06 am
If you use the Crazyswarm or crazyflie_ros, you can evaluate your trajectory on the host PC and send an updated setpoint (pos, vel, acc, w, yaw) using the cmd_full_pose topic.
Oliver
Post by Oliver » Wed Nov 20, 2019 6:37 am
Thanks for you answer, I will have a try.
r0b0tn1k
Post by r0b0tn1k » Tue Nov 26, 2019 9:23 pm
How do you use CrazyFlie ROS?
Oliver
Post by Oliver » Fri Dec 27, 2019 3:20 am
crazyflie_ros is a ros package, the crazyflie_server subscriber some topics, you can publish relevant topics with data to control the crazyflie.
