Info about logging code
antoniodecri
Post by antoniodecri » Wed Nov 06, 2019 9:49 am
Hello everyone, i wrote the code that i am attaching here which is based on the code basiclog.py
I want the drone to log data while it does simple trajectories, moreover i want to log quaternions, positions and so on.
I removed the part of the timer where the link has been closed after a certain period because i want to stop the logging and disconnect right after the drone finishes its trajectories but the led M4 keeps blinking green. Any suggestion on how to solve this issue? Did I code wrong something in my script? Thank you.
logdata.txt
Sorry, i attached the txt because the .py format is not accepted
(13.24 KiB) Downloaded 15 times
Re: Info about logging code
Post by kimberly » Thu Dec 19, 2019 10:01 am
The logging should automaticallly stop if the script comes to an end and the crazyflie should also disconnect. Could you try to remove all the le._lg1.stops, and ._disconnected? I'm not sure if you are allowed to use those functions in this way.
If that does not work, could you please provide us a minimal working example (without the crazyflie flying but just logging) ?
