I'm trying to rotate (yaw rotation that is) my crazyfly 2.0 through UART messages received from an external microcontroller.
So far I was able to receive the UART messages, and even change vx, vy, z and yawRate using the setHoverSetpoint function that I've found in this post (code below)
The problem is, when I'm changing this line
setpoint->mode.yaw = modeVelocity;Code: Select all
setpoint->mode.yaw = modeAbs;(*When sending the first position command - that is from resting to hovering, it does rotate, but then when sending more rotation commands it won't move)
It almost seems like the crazyfly is trying to rotate but something is holding it back. Trying to go over the code did not yield much, but I think there is another control mechanism that prevents me from using yaw in absolute mode.
Did anyone experience such problems when setting setpoints or does anyone have a lead of what else do I need to change/write in order to use setpoints with yaw as an absolute angle?
setHoverSetpoint code:
static void setHoverSetpoint(setpoint_t *setpoint, float vx, float vy, float z, float yaw)
setpoint->mode.z = modeAbs;
setpoint->position.z = z;
setpoint->attitudeRate.yaw = yaw;
setpoint->mode.x = modeVelocity;
setpoint->mode.y = modeVelocity;
setpoint->velocity.x = vx;
setpoint->velocity.y = vy;
setpoint->velocity_body = TRUE;
}Code: Select all
static void spinTask(void *var)
int i = 0;
volatile float newYaw = 0;
char angle[] = "000\n\r";
systemWaitStart();
while (1)
char *pAngle = &angle[0];
i = uart1Getchar(pAngle);
while (*pAngle != 13) {
i = uart1Getchar(++pAngle);
newYaw += 10;
setHoverSetpoint(&setpoint, newVx, 0, 0.2, newYaw);
commanderSetSetpoint(&setpoint, 3);
}Code: Select all
static setpoint_t setpoint;Roei
*Edit: It turns out that all I had to do was changing
setpoint->attitudeRate.yaw = yaw;Code: Select all
setpoint->attitude.yaw = yaw;
