[SOLVED] force multiple decks?
wydmynd
Post by wydmynd » Mon Aug 19, 2019 11:56 am
Due to the known SPI sharing issue with flow and sd card decks, I am trying to make a modified uSD deck.
it has no OW memory so I want to force it using -
CFLAGS += -DDECK_FORCE=bcUSD
problem is, I already use some autonomous code on a "virtual deck" which is forced.
can you force 2 decks?
thanks!
Re: force multiple decks?
Post by arnaud » Tue Aug 20, 2019 7:15 am
Yes, you can just separate them with colon ":". For example:
CFLAGS += -DDECK_FORCE=bcUSD:someAutomation
wydmynd
Post by wydmynd » Wed Aug 28, 2019 6:11 am
thanks! works
