I've noticed that there appears to be a version 4.2 of the Cflclient for windows source code but not an .exe for download. Does this exist and how does one obtain it?
Thanks and keep them in the air!
Cfclient Rev 4.2
Re: Cfclient Rev 4.2
The 4.2 version mainly contains fixes for Mac so that's why there is no new installer yet.
SuperRoach
- Member
Is there a changelog for the actual CfClient? I've been looking to download a newer copy than the original (ubuntu user here), but have been lost looking through the forums.
Maybe it helps you if you have a look at the commits: https://bitbucket.org/bitcraze/crazyfli ... ommits/all
Just a few changes:
- Auto reconnect after disconnect
- Battery bar shows now up to 4,2V instead only 4V
- PEP8 modifications/changes
- Fixed USB3 bug
- Fixed some joystick-mappings
- other minor bugfixes
Correct me if i forgot a important change
Just a few changes:
- Fixed USB3 bug
Well, there is a plan for this but I'm not sure how well it's working out. The plan was to use Bitbucket to give a rough change log by using milestones. The initial version was 2013.4 so after that we have tagged issues that we thought would go into the next version with 2013.4+. Once these were finished we would do another release named 2013.X where X is the month and everything (bugs and features) tagged for milestone 2013.4+ would make up the change log. To avoid a lot of administration we would skip this for intermediate bug-fix releases until the client is more stable. So using this scheme there would be no change log for 2013.4.2 (except for the repo history). The problem (like almost always) has been time vs ambition. The number of tasks tagged for 2013.4+ grew and other things came in the way so there hasn't been a new version yet, but we are working on it.SuperRoach wrote:Is there a changelog for the actual CfClient? I've been looking to download a newer copy than the original (ubuntu user here), but have been lost looking through the forums.
Since you are on Ubuntu I would just recommend you fetch the latest version from the repo using the guide for the virtual machine and install instructions for mercurial.
