Connection Crazyflie with ST-LINK/V2 for Debugging
berkay075
Post by berkay075 »
Hi everyone,
I have ST-LINK/V2 that is shown as below link.
https://www.google.com/search?q=ST-LINK ... VsXW_Ijz1M:
How can I assemble ST-LINK/V2 with crayflie to debug on eclipse.
Can you share picture which has connection of crazyflie with ST-LINK/V2
I also emphasize that i have not any crazyflie debug kit.
Re: Connection Crazyflie with ST-LINK/V2 for Debugging
In order to connect the debugger to the Crazyflie you need a debug adapter (https://wiki.bitcraze.io/projects:crazy ... connectors) since the SWV debug connector on the Crazyflie is not standard. If you want to make a debug cable by yourself you can find the reference of the connector there: https://wiki.bitcraze.io/projects:crazy ... components and you can find the pin-out in the Crazyflie schematic. Though it will not be very simple to assemble as it is a quite small connector.
This image shows the debug adapter kit connected to the Crazyflie: https://cdn.shopify.com/s/files/1/1028/ ... 4x1024.png. The ST-Link can be directly connected to the debug adapter board.
