crazyflie-firmware development
maruf
Post by maruf » Mon May 13, 2019 3:25 am
Hi Guys,
How do you set up the firmware development environment? Is there a way to run/debug/test firmware code?
I need to modify some functionalities in the firmware. I'd really appreciate any hint help?
Regards,
Maruf
maruf
Re: crazyflie-firmware development
Post by maruf » Mon May 13, 2019 3:34 am
Looks like I just found the answer. It seems I can use the VM or docker image: https://wiki.bitcraze.io/projects:docke ... mage:index.
maruf
Post by arnaud » Mon May 13, 2019 9:39 am
You can also install the tools locally if you want to have them installed on your computer. See the build instructions in the Crazyflie firmware readme: https://github.com/bitcraze/crazyflie-f ... pendencies
