hi, all
I use the crazyradiopa to communication with crazyflie2, but the distance only about 10cm, link quality is very low.
why?
crazyflie nrf51 2.4G commnunication distance only 10 cm
- Expert
Re: crazyflie nrf51 2.4G commnunication distance only 10 cm
Hi, this is too low indeed.
What data rate are you using? We have seen that 2M usually works better so this would be the first things to test. You can change the datarate in the Crazyflie client in the menu "connect/configure 2.0".
