crazyflie nrf51 2.4G commnunication distance only 10 cm
justinleeyang
Post by justinleeyang » Sat Sep 01, 2018 8:07 am
hi, all
I use the crazyradiopa to communication with crazyflie2, but the distance only about 10cm, link quality is very low.
why?
Re: crazyflie nrf51 2.4G commnunication distance only 10 cm
Post by arnaud » Mon Sep 03, 2018 8:20 am
Hi, this is too low indeed.
What data rate are you using? We have seen that 2M usually works better so this would be the first things to test. You can change the datarate in the Crazyflie client in the menu "connect/configure 2.0".
